I gambled and maybe I
  #226
Old 02-10-2019, 06:22 PM
schoo's Avatar
schoo
schoo is online now
schoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to behold
Need to get another material list going and spark plugs are on that list a friend said auto light 764? What do you guys think
  #227
Old 02-10-2019, 09:09 PM
Scndsin's Avatar
Scndsin
Scndsin is online now
Du Nawt Seek The Treasure
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
Nice work. Very clean. Will complement your classic just right.
  #228
Old 02-10-2019, 09:31 PM
schoo's Avatar
schoo
schoo is online now
I rotated the engine with the valve covers laying on the heads and could not hear or feel the rocker hit the covers do you think Iím ok or should I remove the baffling at the filler and pcv
  #229
Old 02-10-2019, 09:40 PM
Scndsin's Avatar
Scndsin
You got me on that one. No gasket & just sitting there, I'd say it's OK.
  #230
Old 02-10-2019, 10:02 PM
baddad457
baddad457 is offline
baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.
They clear the steel covers not the baffles in the aluminum ones. The Cobra 5.0's had double layer steel covers with the Cobra rockers. As for spark plugs the plain jane Autolite/Motorcraft copper plugs last as long as the fancy ones.
  #231
Old 02-10-2019, 10:35 PM
schoo's Avatar
schoo
schoo is online now
thanks Iíve made enough mistakes
  #232
Old 02-11-2019, 05:30 PM
Andy Hawks's Avatar
Andy Hawks
Andy Hawks is offline
Andy Hawks is starting off with a positive reputation.
Fun thread - excited to see it through! You're getting close now...
  #233
Old 02-16-2019, 07:18 PM
schoo's Avatar
schoo
schoo is online now
Back from Tucson warm (70í) but so nice here 30 sometiming and snowing off and on now for 3 week pain in the a$$ to work in the shop Iíve been painting parts using a hair dryer in one hand a spray can in the other hopefully get it back in the truck soon
  #234
Old 02-16-2019, 07:37 PM
schoo's Avatar
schoo
schoo is online now
  #235
Old 02-17-2019, 08:08 PM
schoo's Avatar
schoo
schoo is online now
Primed the oil system and put the exhaust manifolds on. going to rig the cherrypicker tomorrow
  #236
Old 02-20-2019, 11:26 AM
schoo's Avatar
schoo
schoo is online now
Having problem with getting the studs on the torque converter to line up with the flex plate. I get real close but no go I get 2 in but the others are off just a little maybe a 1/4 of the stud Iím wondering if turning the engine while pushing on the engine. wish I had the front core off probably 50 -60 bolts holding that together.
  #237
Old 02-20-2019, 12:33 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is online now
70f100longbed has a great reputation on FTE.70f100longbed has a great reputation on FTE.70f100longbed has a great reputation on FTE.70f100longbed has a great reputation on FTE.70f100longbed has a great reputation on FTE.
Got to align the bellhousing to the block before the TC will line up. You should be able to get the trans and engine together and rock the TC back and forth a little in the flexplate. DO NOT use the bellhousing bolts to draw the engine and trans together! This can damage the trans pump in a hurry. I have some long bolts i cut the heads off of to use as guide pins. Make sure the dowel pins are in the block. Also, did you do anything about the wear marks on the converter? To me it looks like the converter has ballooned which would explain the excessive thrust bearing wear.
  #238
Old 02-20-2019, 12:39 PM
Scndsin's Avatar
Scndsin
You've got the bell housing flush tight with the engine (No angle or gaps) & only 2 studs line up?
I use a pry bar or big screw driver to turn the flex plate pivoting on the edge of the trans case.
Slow & a pain if not careful, but it works.
  #239
Old 02-20-2019, 01:27 PM
schoo's Avatar
schoo
schoo is online now
The trans guy said it was the flex plate Iím not sure of anything. As far as lining the bell and block I donít have very much room between the rack and pinion and the oil pan so it has about 1Ē where I can get the block and the bell lined up parallel yes the alignment pins in the block are just engaged into the bell but the studs are just touching the flex plate 2 studs are in there holes but the two at the top of the TC are hanging up like the flex plate is not the correct one.
I did lay the old one on top of the new FP and they looked exactly the same.
Frozz my but yesterday even with the sun. today snowing again
  #240
Old 02-20-2019, 02:53 PM
Scndsin's Avatar
Scndsin
Is the trans bolted down & you're mating it with the hoist?
Quick Reply: I gambled and maybe I
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
