I gambled and maybe I
Old 02-07-2019, 04:37 PM
schoo's Avatar
schoo
schoo is offline
Originally Posted by schoo
Number 8 is above
I think the pattern is a little tighter in the black sharpie Both are number 8 Black is shimmed. 1.7 rockers the push rods are not centered in the holes through the head I’ll have to ck them out as I go
  #212
Old 02-07-2019, 05:39 PM
baddad457's Avatar
baddad457
baddad457 is offline
I wouldn't worry about the pushrods as long as they're not rubbing the head. If they do, then you can use hardened pushrods here. These were made for use with guide plates which are harder than the cast iron heads.
  #213
Old 02-07-2019, 08:39 PM
schoo's Avatar
schoo
schoo is offline
ok I think the pushrods are harden any way
  #214
Old 02-08-2019, 10:00 AM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
Your torque converter is ballooned and shouldn't be used. Nice build BTW.
  #215
Old 02-08-2019, 10:45 AM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
Are you using checking springs?
I'm trying to do exactly the same thing right now, but I'm using Comp's checking springs, and they're not stiff enough for the roller tips to leave a mark in the ink.
But if I try that on the real spring, I force the plunger in the lifter down, effectively making the pushrod shorter than it actually is.
Maybe I should find a different marker and try again with the checking springs.
  #216
Old 02-08-2019, 11:40 AM
Scndsin's Avatar
Scndsin
Scndsin is offline
I used a Moroso set of checking springs that you could compress with your fingers & genuine "dry erase" marker pen...
Yielded a pretty nice witness mark.
  #217
Old 02-08-2019, 03:04 PM
Glaser67's Avatar
Glaser67
Glaser67 is offline
For what its worth I used a dry erase marker and packed my lifter with washers so it was solid.
  #218
Old 02-08-2019, 03:20 PM
schoo's Avatar
schoo
schoo is offline
I checked 10 and the pattern were the same as far as I could tell but the preload was a little inconsistent range was.028 thru .038 I didn’t note which were which I’m fighting the cold in the shop and came back in
  #219
Old 02-08-2019, 03:22 PM
schoo's Avatar
schoo
schoo is offline
the transmission guy said it was the flex plate. How to ck balloon in the TQ?
  #220
Old 02-08-2019, 03:26 PM
schoo's Avatar
schoo
schoo is offline
Good guy
I got my fuel injectors back today Mr. injector did a great job
  #221
Old 02-08-2019, 08:57 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
OK, I need to get some dry erase markers. I don't want to disassemble my lifters; I just know that if I try, I'm going to get springs shooting into the dark corners of my garage, never to be found again.
  #222
Old 02-10-2019, 04:42 PM
schoo's Avatar
schoo
schoo is offline
It’s amazing what can get done if the snow melts
  #223
Old 02-10-2019, 04:57 PM
fordman75's Avatar
fordman75
fordman75 is offline
Must be nice!! I look out my window as more snow falls..
Your engine is looking good!
  #224
Old 02-10-2019, 05:07 PM
schoo's Avatar
schoo
schoo is offline
Smile
the weatherman says the snow is back Tuesday thru the rest of the week but I leave for Tucson Monday
  #225
Old 02-10-2019, 05:10 PM
fordman75's Avatar
fordman75
Yep more snow here to tomorrow/Tuesday, Then more on Thursday. Seems like we're in a little storm train. Every other day or so more snow.
Quick Reply: I gambled and maybe I
