I gambled and maybe I
  #121
Old 12-30-2018, 09:38 AM
baddad457's Avatar
baddad457
baddad457 is offline
Originally Posted by schoo
Some body on here said I will need a different distributor drive gear if I change cams(comp cam#35-512-8)is this true and if so have you got a part#
Only if you go from a flat tappet to a roller cam (or vice-versa) The cam's materials are different (steel for the roller, cast iron for flat tappet)
  #122
Old 12-30-2018, 11:56 AM
schoo's Avatar
schoo
schoo is offline
ok I’m going to roller cam. so steel are they all the same I believe I also will change the firing order
  #123
Old 12-30-2018, 12:43 PM
baddad457's Avatar
baddad457
As far as I know all roller cams are steel.
  #124
Old 12-30-2018, 06:19 PM
Scndsin's Avatar
Scndsin
Scndsin is offline
Itz been a while so I think this was covered, but your 89 block is "roller capable", it will need a "spider" & "dog bones" to go with a roller cam.
Most all hi-perf small block Ford cams usually have the notation in their specs "must use 351 firing order".
You will need a steel distributor gear. I'd also suggest you take the time to replace the PIP sensor in the distributor since you have to press off the gear.
Use a Motorcraft part.
  #125
Old 12-31-2018, 10:54 AM
Last chance 53's Avatar
Last chance 53
Last chance 53 is offline
I am running a comp cam in my 331 and was told by comp that all the cam part numbers that end in -8 are iron based and a steel gear was not needed. Maybe want to double check before you change to steel
  #126
Old 12-31-2018, 01:25 PM
schoo's Avatar
schoo
schoo is offline
thanks guys info keeps me hopping summits got a steel one for $29.99 and also sell comps plastic one for $💯 so I have a good range to choose
  #127
Old 01-01-2019, 01:01 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is online now
The -8 are rollers, so are they steel?
  #128
Old 01-01-2019, 02:17 PM
Last chance 53
The comp cams are a ductile lron core, not billet steel. They use a heat treatment on the lobes to control wear on them.
  #129
Old 01-01-2019, 04:07 PM
schoo's Avatar
schoo
schoo is offline
ok what drive gear am I going to use? I sent an email to comp asking yesterday so don’t expect to here from them soon
  #130
Old 01-01-2019, 05:17 PM
Last chance 53
The tech dept. at comp cams told me I could use the stock iron gear.
  #131
Old 01-01-2019, 05:42 PM
Scndsin's Avatar
Scndsin
Scndsin is offline
Use a steel gear.
This would be fine for your application if you can't a Motorcraft part.
https://www.summitracing.com/parts/sum-850460/overview/make/ford
https://www.summitracing.com/parts/sum-850461/overview/make/ford
Measure the shaft.
(Edit) larger shaft probably for 351/5.8, my bad.
  #132
Old 01-01-2019, 05:45 PM
schoo's Avatar
schoo
schoo is offline
I just found a video by comp cams on summit tech support (I’m old so can’t link it)but it gives a chart and a video shows how to see the difference in cam material and a chart shows drive gear chooses I’m going to use steel
  #133
Old 01-01-2019, 10:15 PM
schoo's Avatar
schoo
schoo is offline
Originally Posted by Scndsin
Use a steel gear.
Measure the shaft.
yes I checked it I have the small shaft
Calling ford tomorrow
  #134
Old 01-02-2019, 11:27 AM
schoo's Avatar
schoo
schoo is offline
Mission creep
Hope this isn’t a bad sign the drive gear for the distributor that I have looks to be a steel/plastic stock drive gear I need to change out I don’t want to change the hole distributor just the gear it has a roll pin and I believe it’s a press on gear. The machine shop I use doesn’t do this so looking around. The ford dealer says it an obsolete part and can’t even get me a part number. A new year project road block?
  #135
Old 01-02-2019, 01:04 PM
Scndsin's Avatar
Scndsin
Scndsin is offline
Wow. That's pretty lame. It's not hard to drive out the roll pin. The physical effort to press off the gear is minimal.
This is the first hit I got on Google. I'm sure there's more:
Quick Reply: I gambled and maybe I
