I gambled and maybe I
#106
For stock engines, the change is small enough that the stock computer should not have any problems. Its effects are greater if you have enhanced other parts of your intake.
I've been running a set in my 87 GT (SD computer) for a few years, and I've had no problems. The engine has a larger throttle body and 1.5" aftermarket headers, but is otherwise stock. I will say that I noticed a drop in power when I switched back to the stock throttle body. I don't drag in the streets, but there is an on-ramp I'm very familiar with, and it's definitely taking me longer to get up to speed with the smaller TB. So my feeling is the 1.7:1 rockers by themselves have very small effects on power.
#107
Ford found a 15 hp increase when they used the full roller 1.7's on the Cobra 5.0. Some came from the friction reduction in the switch to the roller trunnion, some from the increased valve lift (.030 at the valve) and the stiffer rockers (no deflection). They also lowered the oil temperatures. I've used a set now on 5 different engines (same set) that had over 100K miles on them. They seem to last forever.
#108
#109
Ok I went to cam quest and checked out what they recommend I’m still scratching my head on this but they give a component list to help/spend at there site. They say EFI compatible I hope that is SD? Alright the numbers
1. 35-308-8
2. 35-320-8 not sure if SD works here or mas air
3. 35-512-8
So let’s have some input them they are all the same $$
1. 35-308-8
3. 35-512-8
#110
#111
I would use Comp's springs instead of Trick Flows. Also a plain jane Cloyes True Roller timing set for a late model roller 5.0 will save you money I'd bet. That's what I put in my 331 14 years ago ($25 at O'Reillys) still on the job too.
#112
thanks for feed back, timing set $39 it’s not that bad. Tell why comp cam springs over trick flow the price was quite a lot different like $60
#113
That's not a bad price then. I recommended the springs because the rates may be different. Just make sure they're close in specs if you're going to go with them.
#114
#116
Have the rods resized on the big end when replacing bolts. On the crank journals, inspect for any nicks, other damage, hot spots, etc. If they look good just mic. them in a few spots to make sure they are round and within specs.
#118
talked to the transmission guy today he saying that it’s the flex plate that 200k it’s all through flexing and I need a new one
#119
ok checked with summit tech he said what comp cam did was move a new spring (beehive)into there recommended use they used to use a very similar spring to what I will use the trick flow
#120
