I gambled and maybe I
  #61
Old 11-28-2018, 09:42 PM
baddad457
baddad457 is offline
baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.
Originally Posted by schoo View Post
Iím going to use the heAds I have the GT40 heAds are hard to find here
If you are, at least do this: get a set of porting bits and take a die grinder or drill and remove the Thermactor bumps from the exhaust port roofs, if you're getting the heads reworked, also take a header gasket to use as a template and open the walls and port roofs to match the gasket, blending this down into the port. This takes about an hour to do all eight ports and really improves the flow.
  #62
Old 11-28-2018, 09:47 PM
schoo's Avatar
schoo
schoo is offline
schoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to behold
Originally Posted by baddad457 View Post
It's called the F4TE cam. Was used in all pickup/van 5.0's from 94 -96, All Explorer/Mountaineer 5.0's and the roller 351W from 94-97 . Specs are 256/266 advertised duration, .422/.445 lift with 1.6 rockers, 116* LSA. 1.7 rockers increases the lift by .030. Full roller 1.7 rockers netted the 5.0 Cobra engines 15 HP. The stock HO roller is just a step above this one in specs. The Cobra 5.0 cam also works well and similar in specs to these two.
thanks for info. What is a good gasket set for-pro?
  #63
Old 11-28-2018, 09:50 PM
baddad457
Head gasket ? FelPro #9333. I used these on my aluminum headed 331. They sealed for 12 years with all the expansion/contraction you get with aluminum heads on an iron block. I liberally spray them with copper kote before installing them.
  #64
Old 11-28-2018, 11:17 PM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
hairyboxnoogle has a good reputation on FTE.hairyboxnoogle has a good reputation on FTE.hairyboxnoogle has a good reputation on FTE.
You can find them all over the internet, not as cheap perhaps. Especially as you have the engine apart now, i would strongly consider them. E7TE heads are boat anchors, some of the worst castings there were for the small blocks. However, at the end of the day, its your engine and your budget, im just passin along the information.
  #65
Old 11-29-2018, 09:02 AM
schoo's Avatar
schoo
schoo is offline
thank you for info if you see a set of GT40 at a good price post me a link Iím open hope my manifolds fit
  #66
Old 11-29-2018, 09:06 AM
schoo's Avatar
schoo
schoo is offline
I guess I need to get a material list next
  #67
Old 11-29-2018, 01:26 PM
Scndsin's Avatar
Scndsin
Scndsin is offline
Du Nawt Seek The Treasure
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
Look at this way. A stock HO 5.0 makes 225-235 HP with E7 heads & a mild cam with crinkled up stock headers.
Here's my 5.8 build & parts list that I did for right at 3K with me & chapter member turning all the wrenches from crank out & minimal machine work. ( Intake mod not needed for you)
https://www.ford-trucks.com/forums/1...l#post16937337
The 512 Comp cam is listed by them to be the most cam for a stock 5.0/speed density truck & is only mildly more aggressive than my stock 5.8 cam.
What's the back story on this truck? Who did the EFI swap?
Those witness marks on the TC are worrisome.
  #68
Old 11-29-2018, 02:36 PM
schoo's Avatar
schoo
schoo is offline
Thanks dave oh yes I did this truck and the swap minus electric delete chuck did that
  #69
Old 11-29-2018, 02:40 PM
schoo's Avatar
schoo
schoo is offline
And yes need to figure out the TC
  #70
Old 11-29-2018, 05:50 PM
Scndsin's Avatar
Scndsin
Scndsin is offline
Was there a block plate between trans/engine?
  #71
Old 11-29-2018, 06:18 PM
schoo's Avatar
schoo
schoo is offline
I donít have the flywheel off yet is that it
I think itís in this pic
  #72
Old 11-29-2018, 06:44 PM
schoo's Avatar
schoo
schoo is offline
if I change heads to say gt40 is that going to lead a chain reaction with the efi pcm ect
  #73
Old 11-29-2018, 07:40 PM
Scndsin's Avatar
Scndsin
Scndsin is offline
Got it, missed it before.
You can safely get 300 hp by the stock computer & the GT40 heads aren't going to push you past that.
  #74
Old 11-29-2018, 08:56 PM
baddad457
I see you've never actually run a set of ported E7's. They were actually better than the early 351W heads, right outta the box.
  #75
Old 12-01-2018, 01:29 AM
Beanscoot
Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
I was aware that the E7TE heads were considered much better than the late 70s to mid 80s heads (D8OE etc.) but are they actually as good as, or better than the C9OE heads? They do have the advantage of hardened seats, and pedestal rocker arms.
Quick Reply: I gambled and maybe I
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
