I gambled and maybe I
  #331
Old 03-17-2019, 10:25 AM
schoo's Avatar
schoo
schoo is offline
schoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to behold
Originally Posted by Tim Young View Post
I think David is asking about the harmonic balancer, does it have a 0 degree mark at TDC and the degrees BTDC on one side and degrees ATDC on the other? It looks to me as though it just has the degrees BTDC and 0 degrees TDC.
yes all it has is 0 through 40* I think(my eyes are old see post 325 I said I didn't have a OBD and there it is) . No after top dead center markings, I made a blue arrow to indicate which set of timing marks to use when I was matching new balancer to the old balancer
Started down I just felt it
  #332
Old 03-17-2019, 12:27 PM
Scndsin's Avatar
Scndsin
Scndsin is offline
Du Nawt Seek The Treasure
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
Yes. I'm thinking I see nothing but degrees after TDC.
There are things called timing tape, but Henry Help Us, if you can find one for a sbf.
  #333
Old 03-17-2019, 12:54 PM
Scndsin's Avatar
Scndsin
Scndsin is offline
OK, my bad. Looked at a balancer on the shelf & yours shows before degrees & no after degrees.
The pointer lines up with the first zero mark when you find for sure TDC?
  #334
Old 03-17-2019, 02:01 PM
schoo's Avatar
schoo
schoo is offline
yes piston is at the top of stroke 0 on pointer, rotor at #1
the engine started on the third try of the key after assembly it has never been off by very much
  #335
Old 03-17-2019, 02:11 PM
Scndsin's Avatar
Scndsin
Scndsin is offline
Then you should be able to pull the spout, loosen the hold-down & get 10* (second 0, second red mark to the right)
Unless the cap is hitting something. The only other issue you might be having is that 8 inches of vacuum could be some heavy leak.
  #336
Old 03-17-2019, 03:53 PM
schoo's Avatar
schoo
schoo is offline
yes about getting my nerve up here soon.
the only vac line I have doubts about is the egr from the solenoid to the unit will it run if pull that line
  #337
Old 03-18-2019, 05:00 PM
diggerrigger's Avatar
diggerrigger
diggerrigger is offline
diggerrigger is starting off with a positive reputation.
You can disconnect the vacuum line at the EGR valve and plug it. It will have no effect for your purposes at this time.
8 inches of vacuum is way low. Vacuum that low would most commonly indicate a manifold leak. Is the PCV valved line made to the tapped opening on the the rear of the upper intake? I know this connection opening is out of sight, maybe out of mind.
  #338
Old 03-18-2019, 06:19 PM
schoo's Avatar
schoo
schoo is offline
yes PCV is there Ill ck for vac leaks I used studs when I installed the manifolds
  #339
Old 03-18-2019, 06:29 PM
schoo's Avatar
schoo
schoo is offline
I drove it up to town twice today first time I tried it at 12-15 I had to stop and advance it up to 20+ just to get up the hills.
It it heats up to the fan comes when not moving but driving it cools down to 190 or so, when I turned it off I checked the thermostat housing with my gauge and it read 197 just after shutdown.
  #340
Old 03-18-2019, 07:06 PM
Tim Young's Avatar
Tim Young
Tim Young is offline
Tim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputation
Well besides the motor, everything else is working ok?
I would like to see a photo of your truck!
  #341
Old 03-18-2019, 07:13 PM
Scndsin's Avatar
Scndsin
Scndsin is offline
197* is good. 20* I guess will have to be lived with for now.
Are your IAC, throttle body, gaskets new?
Are all the extra ports on the vaccume tree capped?
This thing doesn't have a power brake booster does it?
What intake to head gasket did you use?
  #342
Old 03-18-2019, 09:02 PM
schoo's Avatar
schoo
schoo is offline
Ford had the gas tank in the cab mine (Chevy van Fi tank)is in the rear behind the Chevy rear end, gas cap is jag
everything working ok? This is a hot rod made up from I’m counting 6or7 cars/trucks. Power steering for instance jaguar rack & pinion but the pump is ford E250 the pump is new when I built the engine but the rack seals are old and when I started up the engine I had a lot more pressure than the old pump( the old one worked great)so of course I blow the seals
  #343
Old 03-18-2019, 09:09 PM
schoo's Avatar
schoo
schoo is offline
There are lots of truck on FTE that are sooooo much better than this truck check out some of them on the 48-56 forums
  #344
Old 03-18-2019, 09:52 PM
schoo's Avatar
schoo
schoo is offline
Dave I am going to be checking vac system this week
gasket at throttle body is new
IAC was not messed with
The tree is caped where no hose are
ill check out the lower intake manifold also
yes I have a vac booster for brakes and I have had some trouble with brake fluid leaks at master (Chinese)
  #345
Old 03-18-2019, 11:38 PM
Tim Young's Avatar
Tim Young
Thanks for the update!
Quick Reply: I gambled and maybe I
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
