I gambled and maybe I
  #316
Old 03-15-2019, 11:44 PM
Scndsin's Avatar
Scndsin
Scndsin is online now
Du Nawt Seek The Treasure
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
Originally Posted by schoo View Post
I put the wrench on the balancer bolt and turned just until I felt the piston move
Started down I just felt it the piston that is
So if you've got the wire touching the top of the piston at it's highest travel, the pointer is showing this much before 0?
The balancer.... Is the second red mark a 10? Is it engraved with BTDC and ATDC?
Do you have a OBD 1 connector like this anywhere?
  #317
Old 03-16-2019, 09:05 AM
schoo's Avatar
schoo
schoo is offline
schoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to behold
The wire is on the piston and at this point the piston is moving down
the first red mark is TDC second red is 10
I do not have a OBD that was removed in harness delete (this has been proven untrue see post 325)
  #318
Old 03-16-2019, 10:58 AM
Tim Young's Avatar
Tim Young
Tim Young is offline
Tim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputation
So if I understand you right in this photo is where you determined to be top dead center? I don't think I understand actually. It doesn't look like you have it on TDC to me. You even mentioned the distributer went passed the number location?
  #319
Old 03-16-2019, 11:37 AM
schoo's Avatar
schoo
schoo is offline
l am sorry that is just past top dead the piston is going down (power stroke)the pic is from the right side (passenger side ) marks are moving away from me crank was at 10:00 moving toward 12:00. The rotor has passed the #1 post on distributor cap. I’ve tried to post another pic but my phone gives me to much trouble
  #320
Old 03-16-2019, 02:19 PM
Scndsin's Avatar
Scndsin
That's really unusual. There's really no reason not to have that if this is a factory Ford computer, even altered.
  #321
Old 03-16-2019, 02:46 PM
schoo's Avatar
schoo
schoo is offline
Yes that is my thoughts I am thinking that the components of EEC are functioning as intended but I have added more air intake volume and system is not happy
my chilton’s manual has a statement about driving for 10 minutes to let the PCM make corrections
  #322
Old 03-16-2019, 03:13 PM
schoo's Avatar
schoo
schoo is offline
One more time stabbing TDC
I am within 1 or 2
  #323
Old 03-16-2019, 03:17 PM
schoo's Avatar
schoo
schoo is offline
I have not moved the crankshaft
my phone makes me have 2 posts but is 0 time on the distributor
  #324
Old 03-16-2019, 03:18 PM
schoo's Avatar
schoo
schoo is offline
And you guys laughing admitting I am a trainee here
  #325
Old 03-16-2019, 03:41 PM
schoo's Avatar
schoo
schoo is offline
Look what I found under a relay
Under the heat/ac valve
i was the one who mounted this it must have been a Friday
  #326
Old 03-16-2019, 07:20 PM
Tim Young's Avatar
Tim Young
Ok, I got it. I'm just winging it here but could it be possible that the cam is off by one tooth? Like I said I'm just winging it, I have no idea what that would cause if that was the case.
  #327
Old 03-16-2019, 08:34 PM
Scndsin's Avatar
Scndsin
You can get one of these at any of the big three parts slingers for about 30 bucks.
It can save headaches & stops (slows down) throwing parts at a problem blindly.
If it's running within what you think it should, drive it easy & listen for detonation.
I think you've got plenty room in the EFI for whats in the engine.
Let me ask again, does it show BTDC & ATDC on the balancer?
It looks in the pics like it starts at 0 & goes in one direction which don't make sense.
  #328
Old 03-16-2019, 10:01 PM
schoo's Avatar
schoo
schoo is offline
Code reader on order from amazon be here on Monday
it it does not show bottom dead center nor does it show top dead center. this balancer is a summit universal thing not recommended to anyone it has 3 different settings for different pointer locations I’m sure that I have the correct settings I matched with the old balancer
And no it won’t start at zero I began at the beginning today with checking #1 on compression stroke(with finger in spark plug hole), rotor points at number one post on cap, spout is installed I try starting no go, i bump timing a little and it tries, bump a little past 10 it runs for a second, I push a little more advance it runs a little rough and smooths out (the engine is cold at this time) I check the timing light and it’s 16 or so, it warms up and is trying to advance but running rougher I throttle up some rpm it run ok I let the throttle loose and it stalls
  #329
Old 03-16-2019, 10:25 PM
schoo's Avatar
schoo
schoo is offline
Some more info I also hooked up a vacuum gauge taping into the line for the map sensor with a T fitting the engine is warm and needs to be advance again now at 22 but idling good vacuum is at 8 in.
I do do the same at the EGR and the needle just moves off 0
  #330
Old 03-16-2019, 10:46 PM
Tim Young's Avatar
Tim Young
I think David is asking about the harmonic balancer, does it have a 0 degree mark at TDC and the degrees BTDC on one side and degrees ATDC on the other? It looks to me as though it just has the degrees BTDC and 0 degrees TDC.
Quick Reply: I gambled and maybe I
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
