I gambled and maybe I
  #241
Old 02-20-2019, 03:08 PM
schoo's Avatar
schoo
schoo is offline
schoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to beholdschoo is a splendid one to behold
Originally Posted by Scndsin View Post
Is the trans bolted down & you're mating it with the hoist?
yes to some degree trans is on a jack at it’s front, engine is on the hoist but not all the time it’s on the engine mounts,some times on the engine mount bracket without the mount biscuits but it’s so close the locator pins are in past there bevel about 1/2” or so to go. With 2of the TC studs in gauged in the flex plate and two just on the edge I think I can’t see them at the top of the bell
i marked the hole for the TC drain plug on the flex plate and used the matching one on the new flex plate so?
  #242
Old 02-20-2019, 03:18 PM
Scndsin's Avatar
Scndsin
Scndsin is offline
Du Nawt Seek The Treasure
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
The TC has studs, right, not bolts?
I'll be honest, I prefer to mount the engine & bring the trans to it.
It's easier (for me) to move around & line up.
  #243
Old 02-20-2019, 03:29 PM
schoo's Avatar
schoo
schoo is offline
yes has studs on the TC and Iím pretty sure the TC snout is in the crank pilot hole, drives me crazy and did I say it cold here
  #244
Old 02-20-2019, 04:56 PM
schoo's Avatar
schoo
schoo is offline
pic of when I put the engine in the truck the first time note the chain rig on the hoist bar my micky mouse way to get it out of the van the distributor was hitting on the bottom of that bar the bolt ripped the fire wall insulation out of the underside of the dash,the bar was level to the ground.
you can just make out the R&P at the drop down in the oil pan sump
  #245
Old 02-20-2019, 10:06 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is online now
xlt4wd90 is gaining momentum as a positive member of FTE.xlt4wd90 is gaining momentum as a positive member of FTE.
If you have doubts about whether the TC fits the flex plate, can you try test fitting just the TC t the FP? I mean, pull the TC off the trans and hold it up against the flex plate just to see if the studs would line up with the holes in the FP, and have the TC nose fitting into the pilot bearing. At least you can verify that they DO fit.
  #246
Old 02-20-2019, 10:26 PM
schoo's Avatar
schoo
schoo is offline
That would a good third way to check it like I said I put the new one over the old and they matched the I reversed them so?
  #247
Old 02-21-2019, 12:54 AM
Scndsin's Avatar
Scndsin
Scndsin is offline
Cold? I thought all of Cali stayed at 80* year round.
No heat in your shop?
  #248
Old 02-21-2019, 09:18 AM
schoo's Avatar
schoo
schoo is offline
it is usually nice here we just had a month of this hiís in the low 30ís itís suppose to get to 45 today
I am going to try rotating the engine to see the other end of the flex plate/TC
  #249
Old 02-21-2019, 06:37 PM
schoo's Avatar
schoo
schoo is offline
hope it works
  #250
Old 02-21-2019, 07:29 PM
Scndsin's Avatar
Scndsin
Scndsin is offline
Everything bolted up square ?
  #251
Old 02-21-2019, 09:08 PM
schoo's Avatar
schoo
schoo is offline
Iím still judging that as this is my first auto trans was able to push them together less than a quarter inch to pull with bolts,
i was with my grandson most of the day way more important than an old truck
  #252
Old 02-21-2019, 09:14 PM
schoo's Avatar
schoo
schoo is offline
This was a few weeks ago
  #253
Old 02-21-2019, 09:33 PM
Scndsin's Avatar
Scndsin
Scndsin is offline
Without a doubt in re grand kids.
You should be able to line up the studs on the TC, push the block/trans together.
If you draw them tight & square, there should still be a bit fore/aft movement between the TC/Flex plate & the nuts draw the TC forward to the flex.
  #254
Old 02-22-2019, 09:29 AM
schoo's Avatar
schoo
schoo is offline
going to check it again this morning Iím not happy with the way theTC is going in
  #255
Old 02-22-2019, 11:21 AM
schoo's Avatar
schoo
schoo is offline
wrong pilot bearing
Quick Reply: I gambled and maybe I
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
