Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
*******The Official Superduty Morning Coffee thread*******
  #3076
Old 01-15-2019, 04:21 PM
hydro man 17
hydro man 17 is offline
hydro man 17 has a good reputation on FTE.hydro man 17 has a good reputation on FTE.
David, are you an audiophile? I need to buy a proper cartridge for my turn table and don't really know where to look. I bought may current set up back in the day everybody was saying that vinyl was dead. At the time the only things that were available were cheap junk or items that cost as much as a new truck.
  #3077
Old 01-15-2019, 04:26 PM
Wesley Green's Avatar
Wesley Green
Wesley Green is offline
Wesley Green has a great reputation on FTE.Wesley Green has a great reputation on FTE.Wesley Green has a great reputation on FTE.Wesley Green has a great reputation on FTE.Wesley Green has a great reputation on FTE.
Lol, cruise control. Guess I'm weird, i never use it. Too much of a disconnect to attentive driving vs becoming a passenger/unattentive driver.
  #3078
Old 01-15-2019, 04:28 PM
hydro man 17
Sous, do you have any personal experience with the rear view camera / collision avoidance feature? I've decided that it needs to be part of my requirements since I had the stroke a while back.
  #3079
Old 01-15-2019, 04:29 PM
Sous's Avatar
Sous
Sous is online now
Sous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputation
I use cruise control every chance I get. It makes life easy and helps with the MPG's as well.
  #3080
Old 01-15-2019, 04:31 PM
Sous's Avatar
Sous
Sous is online now
Are you talking about assisted braking for unseen obstacles while backing up?
  #3081
Old 01-15-2019, 04:47 PM
hydro man 17
Sous, That is a concern as well but I am also looking into the camera system as well. I just don't know if it would be more of a distraction than the good it may do.
  #3082
Old 01-15-2019, 05:20 PM
F250_'s Avatar
F250_
F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
Personally, I find that I get better mileage without the cruise, but that's primarily because I get away with letting the speed float upwards over a cruise "setpoint" when going downhill, and then don't have to recover as much with the throttle on the subsequent uphill climb. I've tried it both towing and empty, and I can outperform the cruise either way. I've found this to be true almost regardless of what vehicle I drive.
Still, though.....
That having been said, I use cruise control every chance I get for the exact same reason you stated, Sous.
  #3083
Old 01-15-2019, 05:38 PM
Wesley Green
Originally Posted by F250_ View Post
Personally, I find that I get better mileage without the cruise.
​​​​​​​Same
  #3084
Old 01-15-2019, 06:15 PM
Sous's Avatar
Sous
Sous is online now
Same
You guys are crazy... I will use cruise control if I am going 3 miles at a set speed. I think it is one of the best things ever designed.
I suppose I get better MPG's using CC because my speed will stay constant and I won't find myself doing 65+ in a 55.
  #3085
Old 01-15-2019, 06:18 PM
Sous's Avatar
Sous
Sous is online now
Well, if you find yourself distracted by it you don't have to use it. I like the option to use the cameras, even if the use may be far and few between. I see these features as tools in the box. Not every tool has a use all the time, but when you need that stupid 90 degree bend, extendable faucet wrench, you need it.
  #3086
Old 01-15-2019, 06:24 PM
F250_'s Avatar
F250_
F250_ is offline
That's my point, Sous. If I'm NOT in cruise, when I approach a hill, I let the truck run to the speed it wants to attain, within reason. Then, without having moved my foot position on the pedal, I let the speed (energy) drive the truck up the other side of the downhill thrust, and then catch it up to maintain my target speed only as the speed begins to drop below where I want to run. In that way, I don;t have to give the engine a surge push of power at the beginning of the climb. Granted, ti's not a huge savings, and that's why I typically just let my cruise do it's job, but only when I'm on an open road run which will last more than 10-20 minutes. I love the cruise control, but I can still beat it on economy if I choose.
Depending on traffic, I don;t mind doing 65-70 in a 55, but I generally limit myself to no more than about 7-8 over the limit.
  #3087
Old 01-15-2019, 06:42 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is online now
timmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud of
Doing that stunt here in CA brother, and you'd definitely be shown that your #1..lol
Im with Wes, never will use it again. Find it tryn to "find" itself all the time.
As for Subaru's, id pull the trigger on a CrossTek anyday over any other car..hands down...burnt orange in color
  #3088
Old 01-15-2019, 08:45 PM
ZachinCO's Avatar
ZachinCO
ZachinCO is offline
ZachinCO is gaining momentum as a positive member of FTE.
Originally Posted by Colorado350 View Post
Zach,
The Infinity and Audi are going to be very expensive to repair down the road. A guy I work with drives an Audi A7 great car but damn the repair costs are ridiculous. I donít think you can go wrong with a Toyota, Subaru or even the Kia.
Yeah, figure that kinda goes with any high end foreign job. At least the Mrs has realized that the Porsche Cayenne is to small....
  #3089
Old 01-15-2019, 08:47 PM
ZachinCO's Avatar
ZachinCO
ZachinCO is offline
Just did the timing belt and water pump in my son's '04 Tundra 4.7 this past weekend. Talk about an involved front end tear down to get to the belt and pump.... Geeesh! Since he was wanting learn as we went, and do the work himself, it took us two days to get it all done.
Don't have any experience with the other vehicles you mentioned, but my wife's '10 Lexus RX450h is the quietest and most comfortable vehicle I've ever owned.
Yeah, I'm down to getting the crank pulley off. Lots of work to get to the water pump, it's a PITA!
  #3090
Old 01-16-2019, 10:52 AM
BBslider001's Avatar
BBslider001
BBslider001 is online now
BBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant future
Wes, so in an 8 hour driving day, you never give that right knee and ankle a break and just "cruise"? I don't think that would constitute as "distracted driving". Keeping that leg in the same position for that amount of time would absolutely kill me. LOL
Quick Reply: *******The Official Superduty Morning Coffee thread*******
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
