*******The Official Superduty Morning Coffee thread******* - Page 210 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
  #3136
Old 01-21-2019, 08:31 PM
Wesley Green's Avatar
Wesley Green
Wesley Green is online now
Wesley Green has a very good reputation on FTE.Wesley Green has a very good reputation on FTE.Wesley Green has a very good reputation on FTE.
Coming home after a 12 hr shift to yellow tape boxes is always a welcome relief
  #3137
Old 01-21-2019, 10:21 PM
BBslider001's Avatar
BBslider001
BBslider001 is online now
BBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant future
Ooohhhhhh cheeeyittt.....do tell.
  #3138
Old 01-22-2019, 06:27 AM
Wesley Green
Kinda boring actually, just the updated clutch arm that was ordered in early December , no go fast goodies
  #3139
Old 01-23-2019, 07:30 PM
Sous's Avatar
Sous
Sous is online now
Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.
Watched Bohemian Rhapsody with Rami Malek the other day. Even if you are not a fan of the music, the performance and production of the film was amazing.
  #3140
Old 01-23-2019, 08:10 PM
Wesley Green
1st half of the movie and last 10 min were great, everything else in between can be skipped
  #3141
Old 01-23-2019, 08:16 PM
Sous's Avatar
Sous
Sous is online now
Ya, I could see that perspective. We watched the actual Queen performance at Live Aid on YouTube afterwards, pretty cool to see them back to back.
  #3142
Old 01-24-2019, 08:03 AM
Wesley Green
Paging Alaska brethren, shut the dang door! 13* in OK this morning, wanted to hit the underside with a powerwasher to knock the dust or oil off everything b4 the clutch job today, rather have dust or oil than ice on everything. Y'all stay warm out there
  #3143
Old 01-24-2019, 08:56 AM
Walleye Hunter
Walleye Hunter is offline
Walleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to behold
56* here in PA this AM with heavy rains last night, keep the cold out west, we're not looking for it.
  #3144
Old 01-24-2019, 09:40 AM
brian42's Avatar
brian42
brian42 is online now
brian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant future
It got down to 35F last night at my place and I think I saw two small clouds. I actually put on a light jacket this morning to go to work.
  #3145
Old 01-24-2019, 09:47 AM
Walleye Hunter
Can your heating systems handle all that? Or do you have a heap of electric heaters from Costco's scattered around on extension cords?
  #3146
Old 01-24-2019, 09:55 AM
BBslider001
Mornin' gents....17* here and two more inches of snow. F**** this place. Anyhoo, 5 more days including today and we are out....fingers crossed. I'll be doing some spring overload installing come Sunday thanks to Mark.
  #3147
Old 01-24-2019, 09:57 AM
Walleye Hunter
Let us pray that Mr. Murphy stays away.
  #3148
Old 01-24-2019, 10:20 AM
BBslider001
Yes, lets! Mr. Murphy is no friend of mine.
  #3149
Old 01-24-2019, 04:06 PM
Sous's Avatar
Sous
Sous is online now
Hit a milestone on the solar install for the camper today!
I finished the control panel and wiring the auxiliary monitoring equipment wiring. Vacuumed up my mess I have been making for the past month and then started resealing all of the areas I had drilled holes or broken the foam or insulation at.
I had a bit of time and just couldn't stand it any longer, so I tested just the 12v system in the camper running off the 4 Trojan T105 6v batteries. IT WORKS! Also, nothing blew up! Next will be to get the inverter finished up in order to provide 15A/120v power to the camper and then set the configuration on the Victron charge controller and Victron 712 battery monitor.
It is coming together nicely and I should be done early next week. Then I start working on our library room where I built a door that looks like a built in bookcase with a book to open the latch and everything.
  #3150
Old 01-24-2019, 05:21 PM
Bonanza35
Bonanza35 is online now
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
You know I have solar on my trailer but have yet to figure out how to hook up the inverter for the 15amp/120volt yet. Do you have any good reading about it? I was given a 2500 inverter. Mine seems to work great for the solar, would like to run the TV for the wife without the generator working.
Quick Reply: *******The Official Superduty Morning Coffee thread*******
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
