*******The Official Superduty Morning Coffee thread******* - Page 208 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
  #3106
Old 01-17-2019, 09:55 AM
BBslider001's Avatar
BBslider001
BBslider001 is online now
BBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant future
Originally Posted by Wesley Green View Post
8 hr drives are for amateurs We usually drive to CA 24hrs non-stop, eyes give out long before a knee/ankle and wife and i swap drivers. Seems like i usually end up doing 14-18 hours of the trip. If cruise control held engine rpm constant instead of trying to maintain a set speed I'd probably use it, but until then i still get about 10% better mileage driving than my wife does using CC
Or for those who have two kids and are following behind while pulling 14k pounds
  #3107
Old 01-17-2019, 10:49 AM
Sous's Avatar
Sous
Sous is online now
Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.
Originally Posted by Walleye Hunter View Post
Looks like a complex installation, congrats and hope is serves you well. Will it provide all the power you need with no shore power required?
Shore power will be a nicety after the solar is done. I have room for another 200 watt panel on the roof if needed, but 400 watt should be plenty based on our power consumption.
To answer your question directly, yes this should provide all of the power we need without shore power. A small 2500 watt generator will fit between the two battery boxes which can be utilized to quick charge the batteries or run the A/C for several hours. I ran a test with the generator and with 1 gallon of fuel, the A/C ran for ~8 hours. I installed an EasyStart 364 on the A/C which allows for a much softer and gradual start up instead of the big 15+ Amp surge of power that they draw during start up.
The only thing that we will not have readily available is fresh water. Although, we have 3 collapsible five gallon jugs and 2 seven gallon hard jugs that are made for water in order to fill/refill the fresh tank. For the waste water, we have a trolley for that.
Everything should be covered. The power consumption and charge will be monitored from a fixed gauge at the control panel, but also is capable of being monitored via bluetooth from a tablet, phone or PC.
After it is all said and done, we will have SeeLevel tank monitors that are accurate within 2-3%, WeBoost cell booster, WiFi Ranger WiFi booster, Victron MPPT charge controller, Victron battery monitor, Xantrex 2000 watt inverter, 400 watts of tilting solar panels, generator, 550 Amp hours of battery storage, etc... All with proper gauge wiring to allow for a healthy system to work as designed.
  #3108
Old 01-17-2019, 11:24 AM
slowsure
slowsure is offline
slowsure is starting off with a positive reputation.
Talking
Not that you thought about any of this at length....
Sounds like you have it covered Sous! Very Nice!
  #3109
Old 01-17-2019, 12:18 PM
F250_'s Avatar
F250_
F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
Originally Posted by ZachinCO View Post
I've tried loosening the nut with my impact, no dice. I'm gonna have to get a pulley wrench of some kind. Bummer, I have to buy a new tool....
Thankfully it's not a real rush, we have my daughters FJ right now while she's down in FL the next few months for work.
It took bit for my impact to break the nut loose, and I thought that I might have to resort to the breaker bar and bump-starter technique and let the starting engine torque break it loose for me. It might work for you, too... just make sure to secure the breaker bar on the frame and stay out of the engine bay and out from under the car before the starter is bumped.
  #3110
Old 01-17-2019, 05:10 PM
Wesley Green's Avatar
Wesley Green
Wesley Green is offline
Wesley Green has a very good reputation on FTE.Wesley Green has a very good reputation on FTE.Wesley Green has a very good reputation on FTE.
We only have have 4 kiddos
  #3111
Old 01-17-2019, 10:18 PM
ZachinCO's Avatar
ZachinCO
ZachinCO is offline
ZachinCO is gaining momentum as a positive member of FTE.
Originally Posted by Colorado350 View Post
What kind of impact are you using Zach? Try tightening a bit then loosen it.
Using my pneumatic, wide open. Might not be enough torque. I've got a DeWalt 20v, but don't think that is enough either.
  #3112
Old 01-17-2019, 11:58 PM
Colorado350's Avatar
Colorado350
Colorado350 is offline
Colorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to behold
Id try the Dewalt 20V, assuming its 1/2, its back off torque is over 1000 Ft/lbs. I have several pneumatic both 1/2 & 3/8 and the Dewalt in reverse smokes them both. Im not sure what the HF Earthquake impact rating is but its a beast too. If you wanna try it let me know, you have my number.
  #3113
Old 01-18-2019, 12:17 PM
ZachinCO's Avatar
ZachinCO
ZachinCO is offline
Thanks John, I'll let you know. This next week is a busy one, so might be another week before I try.
  #3114
Old 01-18-2019, 06:42 PM
MoBill122's Avatar
MoBill122
MoBill122 is offline
Papa Smurf
MoBill122 is gaining momentum as a positive member of FTE.
" Here's a thought that we can dig into...
While driving six hours yesterday on back county roads to attend a prebid meeting for a prospective job for our company, I began remembering when I used to do a lot more day-tripping to client locations, and recalled the "Superduty Wave" -- the friendly acknowledgement and greeting towards other SD drivers... it was something I've neither seen much of nor thought much about in the last couple of years. Yesterday, though, I began watching for those "waves" from other SD drivers in the oncoming traffic lanes, and saw very few waves initiated from other SD drivers and very few responses to my initiated waves. I was slightly surprised. It has always seemed that most of the country folks driving the back county roads have generally always been more "friendly" in the years gone by.
Are you guys seeing the same thing? Are we all just too busy and/or too distracted with our growing accumulation of electronic gadgetry to even notice the oncoming SD drivers?[/QUOTE] "
When I grew up over there in north Alabama, seems we all waved at each other going down those country roads. Over here in Atlanta, they might think you're waving a gun at them ! I wave a lot at SD's but don't see many return the wave in this area. Maybe out in the rural areas it would be different
  #3115
Old 01-18-2019, 06:46 PM
Sous's Avatar
Sous
Sous is online now
Everyone still waves at everyone here in the north GA area. Although, it is not common as I get out into the more urban areas. Distracted driving, fighting with kids, whatever, people are just too busy or don't give a damn.
  #3116
Old 01-18-2019, 07:05 PM
MoBill122's Avatar
MoBill122
Papa Smurf
Yesterday I went to the north Georgia mountains, to do some clean up work at a cemetery we help maintain. Having made a trip to Alabama the day before, I knew I'd be pushing my luck with the amount of fuel left in the tank. Anyway, on the way out of the mountains, the Warning light came on... but at that time I was going up and down mountain roads, so I knew I had more fuel than what was showing at times. I have some 50 miles or so to make it to the Kroger fuel station I want to get to, as diesel there is 20 cents cheaper than diesel at Kroger by my house.... and I have fuel points, so I'm looking at saving 50 cents a gallon.... $2.39 I call home.... no answer... I call the wife's cell... no answer.... WTH ? She calls back from the beauty parlor.... I tell her I'm driving on fumes, that she may have to come rescue me. She tells me I better stop for fuel.... and if I'm stupid enough to run if dry, I best call AAA, as its raining and I'm not messing up my hair for your dumb ***.... geezzz Anyway.... I made it to Kroger..... 28.2 gallons..... How much more does that tank possibly hold ?
The past 24 hours.... has been one mess up after another. Last night, I threw my stinky clothes in washing machine.... and didn't know until later, I washed my Infiniti key fob.... but it works !!
Today, I change my oil and in the process dump a quart of dirty oil on the driveway.... that I just pressure washed last week !
Then, I change fuel filter..... and yea,.. the gasket doesn't seat, and damn diesel sprays all over the truck... and the driveway !!
So then, I had to wash the diesel off, so washed the entire truck.....
Was going to replace air filter.... but I thought... I might just blow up the damn truck if I do that today !
Thinking I'll go drink me a JD & coke now...
  #3117
Old 01-18-2019, 07:16 PM
bigb56's Avatar
bigb56
bigb56 is offline
bigb56 is a splendid one to beholdbigb56 is a splendid one to beholdbigb56 is a splendid one to beholdbigb56 is a splendid one to beholdbigb56 is a splendid one to beholdbigb56 is a splendid one to beholdbigb56 is a splendid one to behold
Around here a lot of people wave with their middle finger
  #3118
Old 01-18-2019, 07:27 PM
BBslider001
Hahahahahahaha.....sounds like California....actually drivers there are pretty friendly. I am surprised that this is more true for Nebraska. I have waved at people and they just look at me....in rural ranchland Nebraska! Go figure.
  #3119
Old 01-18-2019, 08:55 PM
hydro man 17
hydro man 17 is offline
hydro man 17 has a good reputation on FTE.hydro man 17 has a good reputation on FTE.
I used to get head light flashes when I had my old BMW. Took a while to figure out that it was just hi sign from other 2002 BMW guys.
  #3120
Old 01-18-2019, 11:01 PM
BBslider001
Winter
Quick Reply: *******The Official Superduty Morning Coffee thread*******
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
