*** The Official Superduty Morning Coffee Thread ***
#2719
Originally Posted by mecdac;18324299[left
We took it to the CAT scale near Emerson after loading all accoutrements.
#2720
#2721
Really curious what your axle weights are without the TT hooked up and what kind of WD you are using. Is the GVWR on the EX 8,800 like the F-250's? My F-350 4X4 front axle weighs in at 5K and I am wondering if you need more WD as your front is only at 3,780 and you look a little nose high.
The picture was taken before raising the ProPride hitch jacks. According to the numbers I probably should raise them even more. As of now, I'm leaning toward an Airlift system thanks @Sous .
It didn't seem "light in the front" and was not affected by winds and semis as much as the previous TT.
#2722
The PP or Hensley i the best hitch you can buy for a bumper pull and you won't get sway, just be careful to get your distribution correct as that hitch tows so well it can mask an improper setup. In case you didn't know you can call Sean at ProPride to ask questions about your setup, he is amazingly helpful.
#2723
I'm using this hitch. IIRC, GVWR on an Excursion is 9200.
#2724
I don't think you are sitting that low. The only thing I will say about airbags, speaking from personal experience, is to be careful with a bumper pull. They affect the way the WDH will handle and it is a B***** to get set up properly. With the hitch set up just right, you shouldn't need them.
#2725
Thanks for all the insight, guys.
#2726
Since we’re talking ProPride here...there were a couple of times this summer where I just couldn’t get the stinger into the socket. Everything was aligned and level, but something would jam and the whole shebang would skew sideways and I’d have to try again. Once in July I must have taken 12-15 tries over 45 minutes before it finally worked. I think it’s the sharp-ish edge of the stinger getting jammed into the side of the socket and catching. I decided to do something about it finally...
Before
After!
I’ll get it painted up and ready to go for the spring. It’ll be then when I find out if my PP mod works.
Before
After!
#2727
WTF
Before
After!
Before
After!
At a trailer hook up.
I picked up a lightly used unit in Charlotte on a tip from our fellow Excursion brother @ExxWhy . One of the best acquisitions I've ever made.
I measure (the middle of the receiver) and try to align as best as possible. I know you're a smart guy, you may have found a new trick.
#2728
An idiot decided to poach himself a deer practically in my front yard last night. I live in a rural area but we have a cluster of 5 houses right here and we all heard it. Then when I went out there he was crying about how he needed it to feed his fat, lazy self. He was about 5' 9" and #250 or so. Claimed he's on disability too, how was he going to load it up then? Into his new Subaru too, I told him to sell his $@!% car and go to the grocery store. Called a friend who came and got the deer. And the police didn't seem to want to be bothered, they never even came out.
#2730
Mine also started to look like garbage as the chrome finish started to fade and flake off. I removed them and replaced them with the '05-'07 style chrome badges. They look better against my Toreador Read paint and, surprisingly, they were cheaper than the '02-'03 7.3L replacements.
Unfortunately it looks like the vendor I bought mine from years ago is not longer around (it was something like fordemblems.com or similar). I think I paid a little under $300 shipped for a full "set" (2 quarter panel badges, 2 door badges, and 1 tailgate badge).
The easiest way I have found to remove badges is a little heat (either a heat gun or a little while in direct sunlight will do in a pinch) and some fishing line, then clean up any residue with rubbing alcohol and finish with a little waterless car wash (Meguiar's or your brand of choice).
Fun fact: I used to get compliments on my truck ("its' a 7.3L? Nice truck") and approving nods from others, but since I've been sporting the 6.0L badges for the last few years I get disapproving stares and no friendly nods...not even from the 6.0L trucks . Maybe they spot the 2nd generation (coil fronts) badges on a 1st generation (leaf fronts) truck .
5:33 - I know exactly what that look feels like!
