Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
*******The Official Superduty Morning Coffee thread*******
  #1906
Old 06-30-2018, 11:20 AM
brandon_oma#692's Avatar
brandon_oma#692
brandon_oma#692 is offline
brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.
Originally Posted by BBslider001 View Post
Where ya headed?
about 5000 miles round trip. Illinois to Arizona then up to Yellowstone then make our way back home.
  #1907
Old 06-30-2018, 11:22 AM
brandon_oma#692
Where ya headed?
https://www.ford-trucks.com/forums/1...am-i-nuts.html
  #1908
Old 06-30-2018, 11:24 AM
BBslider001's Avatar
BBslider001
BBslider001 is offline
BBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant future
Whoop!! Send photos and keep us posted! Sounds like a good time. You'll be close to my stomping grounds down there in AZ. If you run into any issues close to Nebraska, give ma holler.
  #1909
Old 06-30-2018, 11:46 AM
SaintITC
SaintITC is offline
SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.
Originally Posted by Walleye Hunter View Post
You're in DELCO, aren't you? I hadn't heard that they had made it that far yet. If you see them do whatever you can to kill them, they multiply like you wouldn't believe and a lot of pesticides won't touch them.
Yup, and following the link you provided we're in the quarantine area, so I'm not the first to spot them. I'll have to look again to be certain that's what I saw. We're in a very suburban area, not too many farms around, but there are plenty of large wooded areas and large parks and such.
  #1910
Old 06-30-2018, 09:47 PM
brandon_oma#692
Glad I rotated tires today. I had kinda forgotten that when I went to do my rear brakes I only did the drivers side when the slide puns stuck and I wrecked the rotor.
Passenger side needed pads and they were a pain as I expected. Only thing you can get on the upper caliper bolt is a 24mm wrench. Had to use a floor jack to push on the wrench to break it loose then double wrench it the rest of the way. Really glad the rotor was OK so I didn't have to pull the hub off and mess with all that.
  #1911
Old 07-01-2018, 08:25 AM
BBslider001
I just did my rear brakes a few days ago. I heard grinding and thought "oh crap". I'll have to post a photo because the pass. side was toast due to a stuck slide pin. I could NOT get thing out with anything....heat, vise, spray lube buster...NOTHING. So, I had to put it back together with a new rotor and pads to use for getting my horses home, but I'll be taking it apart this week again with a new caliper bracket and pins while crossing my fingers that the new rotor is ok.
  #1912
Old 07-01-2018, 08:28 AM
BBslider001
Ummm, yeah, not supposed to look like that.
  #1913
Old 07-01-2018, 01:23 PM
SaintITC
SaintITC is offline
Wow, I haven't seen an LP in years!
  #1914
Old 07-01-2018, 01:28 PM
SaintITC
SaintITC is offline
Never buy an old stone house, at least not one from the 40's. And if you do, don't replace the front door. But if you do that, don't do it on the hottest flippin' weekend of the year. But - oh I'll just skip to the end. Front door replacements are not supposed to involve 6 hours with a jackhammer.
  #1915
Old 07-01-2018, 02:23 PM
brandon_oma#692
Attachment 261251
does yours just slip over the wheel studs? I miss them on the 250. When I did the rear on the 450 to get the rotor off I had to remove the axle shaft and hub / rotor assembly then unbolt the rotor from the hub.
Yep mine was about that bad too.
  #1916
Old 07-01-2018, 07:33 PM
BBslider001
And it sounds good too!! LOLOLOL!!!
Yeah, mine just slips over. The brakes are as easy as the front as far as working on. I wonder why it's different on the 250 or the 450?
  #1917
Old 07-01-2018, 09:47 PM
Bonanza35
Bonanza35 is online now
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
It's only different on the duallies. I have one, lot more work.
  #1918
Old 07-01-2018, 10:31 PM
hydro man 17
hydro man 17 is offline
hydro man 17 has a good reputation on FTE.hydro man 17 has a good reputation on FTE.
I have lots of them, and most still sound brand new. They are making a come back in some circles of audiophiles.
  #1919
Old 07-02-2018, 07:54 AM
schlepprock250's Avatar
schlepprock250
schlepprock250 is offline
Guns Dont Kill People..
schlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to behold
Good morning from Myrtle Beach. This is the first time in about 12 years we've come to the beach without the camper. We're in a condo for the week. We drove my wife's Imapla down.
  #1920
Old 07-02-2018, 07:56 AM
Sous's Avatar
Sous
Sous is online now
Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.
Enjoy your time at the beach! Did you guys get any of that storm that rolled through north GA last night?
Quick Reply: *******The Official Superduty Morning Coffee thread*******
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
