*******The Official Superduty Morning Coffee thread******* - Page 111 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
  #1651
Old 05-17-2018, 09:17 AM
Sous's Avatar
Sous
Sous is offline
Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.
Not saying it is right or wrong for your application, but look into the T4/SXE setup. The kit and parts really are nothing more than a bunch of bolt on pieces that I have already removed and/or replaced anyway.
Then take into account the funds you would make back by selling the parts you replaced, they are really quite close to each other.
Here is a link to a thread I recently did comparing the two and how I made my decision.
https://www.ford-trucks.com/forums/1...been-made.html
  #1652
Old 05-17-2018, 02:09 PM
Bonanza35
Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
If your talking to me Sous I love to but I don't think I could get it pass smog here in Cali. The KC38R mit even be a problem. My guy is pretty good but even he will only go so far. You would think because it's part of the intake system it wouldn't matter. They are exempt, but even now some want the carb numbers.
  #1653
Old 05-17-2018, 02:11 PM
Sous's Avatar
Sous
Sous is offline
Yes sir I was... Although, I neglected to look at your location first before posting about the T4/SXE. My mistake.
  #1654
Old 05-17-2018, 02:15 PM
BBslider001's Avatar
BBslider001
BBslider001 is online now
BBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant future
I miss my home, but so dam glad I left. This stuff can suck it.
  #1655
Old 05-17-2018, 02:16 PM
Bonanza35
No problem. I like suggestions. Sometimes it gives you second choices. If the wife hadn't had health problems this year we mit of already been looking for some other place to move. It's a little hard with the grand kids here and my son and family. But she wants to after all these years. I tried to get her to do so 35 years age and know way.
  #1656
Old 05-17-2018, 02:42 PM
brian42's Avatar
brian42
brian42 is offline
brian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant future
If your talking to me Sous I love to but I don't think I could get it pass smog here in Cali. The KC38R mit even be a problem. My guy is pretty good but even he will only go so far (making a 38R my only viable potential option if I want to ditch the stocker). You would think because it's part of the intake system it wouldn't matter. They are exempt, but even now some want the carb numbers.
Up to the turbo is no problem as long as there's a filter on it. After that, though, is when you start rolling the dice. I've heard that as long as GARRETT is stamped on the housing you should be okay. Outside of that and you take your fate (and wallet) into your own hands. I can tell you that they know about the red/green lines, wastegate controller solenoid, and diaphragm wastegate controller. If you don't have those (and the lines connected) then you won't pass uless you have a "friendly" shop. Mine was friendly two years ago but not nearly as much this time around. I did get some things by (no EBPV, Hydra, FRx, OCR) so they weren't completely **** but the air lines were a sticking point.
  #1657
Old 05-17-2018, 04:42 PM
Colorado350's Avatar
Colorado350
Colorado350 is offline
Colorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to behold
Ok, WTH is up with the new updates to FTE? I try paging up after posting or reading and it continuously loads all the pages which makes it practically impossible to search threads.
  #1658
Old 05-17-2018, 05:01 PM
Sous's Avatar
Sous
Sous is offline
It is called "endless scrolling" or something like that. I read it in the update notes.
Although, I am seeing the thread jump to the Excursion section once in a while when scrolling up or down, which is strange.
  #1659
Old 05-17-2018, 05:17 PM
Colorado350
Thanks Sous, can it be shut off? Damn itís annoying! Iíve noticed the same thing with regards to jumping forums.
  #1660
Old 05-17-2018, 07:56 PM
machmedic
machmedic is offline
machmedic is starting off with a positive reputation.
You can turn off the endless scrolling in your settings. I did because I like going page by page. If it ain't broke don't fix it, just my opinion.
  #1661
Old 05-17-2018, 08:21 PM
jhl3's Avatar
jhl3
jhl3 is offline
jhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to behold
Endless scrolling.........sucks! Yes, you can turn it off in settings; however, from my experience, it only works when you are logged in. Has anyone figured out a work around for when you are not logged in? Somehow, I can find myself in the Big Block 460 section with endless scrolling enabled due to the "Related Thread" update.
What do you guys think of the "Related Thread" relevancy? There is no relevance....at least on my computer. LOL! REALLY? You can turn that off too, thank goodness.
Anyone else having issues posting pictures at times?
What happened to the emoji?
Maybe I am just extremely challenged....to the MAX.
  #1662
Old 05-17-2018, 11:02 PM
Wesley Green's Avatar
Wesley Green
Wesley Green is online now
Wesley Green has a very good reputation on FTE.Wesley Green has a very good reputation on FTE.Wesley Green has a very good reputation on FTE.Wesley Green has a very good reputation on FTE.
Crappy 16 hr day at work. Oh well, going camping the next 4 days
Finished solidifying the summer trip yesterday too
Just a couple miles in 4 weeks. Need to edit my packing list. The oil change pan may not fit in the suitcase
  #1663
Old 05-18-2018, 07:18 AM
Sous's Avatar
Sous
Sous is offline
I'm OK with endless scrolling, but may turn it off.
Related thread, turning that crap off right after I finish posting here.
Posting pictures is a nightmare compared to what it was. The forum now loads and shows the picture in the reply box instead of just the link, maybe we can change that too?
Emoji is one at a time now. I just copy and paste the text characters if I want more than one.
We are all challenged...
  #1664
Old 05-18-2018, 09:40 AM
BBslider001
Wesley, that looks like one heck of a trip! Hopefully you will get some great photos to share with all of us
I am not sure why they changed the forum format. It seems like a poll would have been nice to ask the people that actually use it, but I guess that doesn't happen anymore. At least you can shut it off because that endless scrolling is pretty frustrating!
Well I guess tomorrow is another day of rest from the week inside since it will be sleeting and cold. It's been 80s all week, so no complaints though. As long as we have no calving or animal emergencies, it should be a great day of catching up on some boob tube time.
  #1665
Old 05-18-2018, 09:44 AM
Sous's Avatar
Sous
Sous is offline
We started watch Catastrophe last night on Amazon Prime, it is pretty funny. If you are looking for a comedy show and want something new, give it a shot.
Quick Reply: *******The Official Superduty Morning Coffee thread*******
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
