Forged pistons stock ?
I was watching something on u tube where they took a mustang 5.0 and put a turbo on a stock motor, they mentioned 87 - 92 years should work. Which leads to my question, did they ever put forged internals, pistons or anything else in the 5.0 or 5.8 truck motors (or maybe only mustangs or other HO ) ? If so do you know which years ?
It has been said on this thread several times that trucks never got the HO 5.0. I have a 96 with a 5.0 backed by a 4r70w. According to the firing order it is an HO 5.0. That being said I am sure it has hypereutectic pistons not forged, also the cam spec is a bit smaller than that of a Mustang HO. My understanding it that it is .422 lift 198 duration on the intake and .448 lift 20something duration on the exhaust. To answer your original question about the rockers the best way to make certain it will work is to get some clay and a solid roller lifter and check the clearances while you have it apart. It would be cheap insurance.
I think he posted in wrong thread, because he also said " To answer your original question about the rockers the best way to make certain it will work is to get some clay and a solid roller lifter and check the clearances while you have it apart. It would be cheap insurance"
northeaster79
01-15-2009 12:09 PM
phoneman91
12-11-2007 08:29 PM
HFCA
12-27-2004 06:47 PM
f100guy
10-04-2004 10:21 PM
