Starter doesnt do anything when key on
Old 08-13-2017, 05:12 PM
MikeTexas3878's Avatar
MikeTexas3878
MikeTexas3878 is offline
My 1994,2.3l,4 cyl Ranger will not start. When I go to start it, it makes a single clank type sound and that's all.
Old 08-18-2017, 09:05 AM
tomw's Avatar
tomw
tomw is offline
If it is a manual, put it in 4th, and rock the truck. That will move the flywheel a smidge. Then maybe the starter gear teeth will engage.
Sounds like your starter or ring gear teeth are worn, or the battery is low on charge, or the starter relay semi-functional. All the above can cause the starter to clank, and fail to turn the crankshaft. The solenoid on the starter, if separate, could also be failing. The older starters had a 'ramped or tapered bump' on the starter which functioned the same as an external solenoid.
tom
WaveyDavey1980
04-18-2019 09:31 PM
kandim123
03-31-2013 06:06 PM
Kendrick
04-09-2011 08:58 PM
Wynn96
04-07-2008 11:58 AM
Unimog005
01-29-2005 09:37 AM
Quick Reply: Starter doesnt do anything when key on
