rain sensing/auto wipers
So i picked up the truck from the dealer yesterday and drove 300+ miles home and it rained the whole way in varying degrees. initially the auto wipers were pretty cool when the ran was so lite the delay was longer than most delayed wipers go. but as the ran became a little harder the auto wipers started varying there speed drastically from just right to delayed wiping with me waiting for the next wipe to see clearly to high speed wiping like it wanted to throw the wipers off the truck. where is the sensor, and is mine off or need adjusting? i thought i would look at the advanced settings today to see if there is a setting to disable the auto sensing until it gets fixed.
thx,
thx,
In my experience, what you described is fairly normal. Because of the intensity variation of rain hitting the windshield the wiper rain sensor doesn't always respond as we think it should. There are more settings for the automatic wipers. I don't think there's anything can be done to change the way it works.
Agreed, my 16 F150 Lariat auto wipers worked much better than the F250 for some reason. With the 250 they seem to go into high speed much faster than needed.
To you question about where it's located. Top of the windshield in front of the rear view mirror. I made the mistake of having the ignition "on" listening to the radio while washing the truck one day. When the wash wand hit that area, the wipers hit the wand and tossed it. Lesson learned.
Auto wipers are cool, but need improvement. I think adding one or two more additional infrared sensors (maybe one low on drivers side and one low on passenger side) would greatly improve the accuracy. You can still switch the wipers on to a steady speed or fast speed manually. Obviously, all the different hash marks on the wiper control allow you to vary the sensitivity. But in general, mine work somewhat inconsistently as you describe.
You might be able to turn rain sensing wipers off completely in the menus.
You can shut the auto feature off in the menus, but you do have to be stopped in order to do it. Usually when it acts up I'm not in the mood to pullover to make the change. Mine worked almost perfectly on my '16 F150 King Ranch, so Ford has the ability to make it work. It baffles me why they can't make them work the same on a F250.
