HVAC Fan Speed Sometimes Stuck in High (Max Speed) - Ford Truck Enthusiasts Forums
Old 08-13-2017, 12:20 PM
BMWBig6's Avatar
BMWBig6 BMWBig6 is offline
BMWBig6 is starting off with a positive reputation.
After owning the truck for more than 5 years, the fan speed in AUTO mode on my 2011 Lariat Limited (dash picture below) always settled down to a more moderate setting after the cabin had cooled off (or heated up in the winter). And I can usually manually override the fan speed by adjusting the temperature by one degree. This summer is the first time I've noticed it sometimes staying in the highest fan speed indefinitely, and it only seems to do it maybe 15% of the time. I can confirm it's stuck by adjusting the temperature by several degrees (which would normally make the fan speed slower). I usually notice it's happening once I'm 10 minutes down the road and my A/C is still blasting at maximum airflow. I have no other symptoms, noises, or problems with my A/C performance--everything works great except for the sticky fan speed in "Auto" mode. And when the system selects a slower speed, the other fan speeds do work fine (which seems inconsistent with what other people reported when their blower motor resistor went out). It seems that the only way to override the max fan speed is to power off the HVAC momentarily and then turn it back on to reboot the system. This usually restores proper function and the airflow resumes at a more appropriate medium setting (that is much quieter too).
Based on a quick search of the archives, my research suggests this may be the beginning of a blower motor resistor failure, but it seems most of those people had a different style HVAC control panel (with round dials to adjust fan speed?) and the automatic systems are "pulse width modulated." Am I barking up the wrong tree?
Old 08-13-2017, 02:14 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.
DATC-equipped vehicles don't use resistor packs, they use a blower speed control module.
It's either the BSC module or the DATC module.
Old 08-14-2017, 10:30 AM
BMWBig6's Avatar
Thanks. Are those easy to test and replace?
Help diagnosing A/C readings. dixie460 1987 - 1996 F150 & Larger F-Series Trucks 7 07-30-2017 09:25 PM
Blower Motor and Resistor R&R with pics... Nicmike Excursion - King of SUVs 19 07-03-2016 10:55 AM
Resistor changed - blower still not working duvaller Explorer, Sport Trac, Mountaineer & Aviator 7 09-03-2015 02:18 PM
Blower motor resistor location 99 EB ronjeremy6 1997-2006 Expedition & Navigator 3 06-20-2010 09:47 PM
A/C blower not working at any speed? deadscout 1997 - 2003 F150 3 06-03-2008 12:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
