Rear Differential Cover for a 2002 F150 with a fill plug (12 bolt pattern)
I need to do have some work done on the rear differential, but the fill plug is frozen in place. The mechanic recommended finding a new Rear differential cover, with a fill plug built in. The cover has a 12 bolt pattern (I think its a 10.25 ring gear size). I've looked high on low and can not find a cover with a fill plug. Any help would be appreciated.
You can customize the finish and add a fill or even a drain plug here:
Ford Sterling 10.25/10.50 - Chrome Differential Cover - Ford Super Duty
canister
21
02-11-2010 11:25 AM
