moog 844, cooper ht3 review - Ford Truck Enthusiasts Forums
Old 08-13-2017, 11:06 AM
'89F2urd's Avatar
'89F2urd '89F2urd is online now
'89F2urd has a good reputation on FTE.'89F2urd has a good reputation on FTE.'89F2urd has a good reputation on FTE.
Just wanted to share my experience with this setup, the 844 springs are the best ~60 bucks I've ever spent. Ride quality is just what I wanted, massive improvement over stock trash springs, and picked up 1.25-1.5" of height. Wish it added more, but couldn't be happier with them overall.
Then, got a set of 265/75/16 of the cooper ht3 and I'd absolutely recommend them for ttb or twin I beam trucks. The solid shoulder rib of the tires are beefy, almost as if specifically designed for any independent front end that is inherently harder on front tires. They're quiet and super smooth, so much that I've been thinking the truck shut off when I'm slowing down. I've had a lot of different tires over the years, I'll be getting these on all my street trucks.
Old 08-13-2017, 12:29 PM
GoinBoarding GoinBoarding is offline
GoinBoarding is gaining momentum as a positive member of FTE.GoinBoarding is gaining momentum as a positive member of FTE.
I like the cc844 as well. No longer bottoming out off road, much more stable but not harsh. Add Bilstein and it makes for a great ride. My SCSB went up 1.25" then I added a big washer under the spring to get to 1.5". 2.75 degree camber bushing's got the alignment close enough until I get new tires.
Old 08-13-2017, 12:41 PM
'89F2urd's Avatar
I'm thinking about milling a 1/2" piece of aluminum with a 1/4" steel plate on top of that to bump it another 3/4 before I get it aligned....I maxed out the camber bushings and I still have a little room left to lift and there's about an inch of stud left on the spring mount.
Where did you get your washers?
Old 08-13-2017, 01:28 PM
They were in a bucket at the family's fab shop, no idea where they came from originally. They're huge, and fit perfectly.
Cooper Discoverer HT3 LT275/70/18 ("33.2") Pics young_bucka 2009 - 2014 F150 5 03-06-2017 05:35 PM
F250 7.3 wheels & tyres thread SSSimon Australia Chapter 30 02-17-2016 03:18 PM
Cooper Discoverer H/T tires JOE SKI 1997 - 2003 F150 3 12-17-2013 08:02 AM
Locker for 2wd trailrider121 1987 - 1996 F150 & Larger F-Series Trucks 51 02-20-2012 04:22 PM
Moog cc844 swap question bigred1992 1987 - 1996 F150 & Larger F-Series Trucks 26 08-24-2011 12:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
