Gasping for fuel? - Page 2 - Ford Truck Enthusiasts Forums
Gasping for fuel?
Old 11-12-2017, 07:08 AM
Tedster9's Avatar
Tedster9 Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Ford used the same distributor for a lot of trucks from '57 to '73, so the module is the same as well. Something ending in part number 1281 should work. Check their website to be sure. But it's a drop in replacement for the points. Make sure the distributor is otherwise in good shape, it's the "brains" of the entire ignition.
Given some of the coil quality issues these days (for now) if I were you and was to go this route I'd recommend the Pertronix I ignitor. The mustard top coil was just fine and provides all the spark you'll need. The ignition and plugs only draw what is required, maybe 5k or 10k volts.
Truck won't start! Sat 10 years, got it running, then it died again. MWB323 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 06-01-2017 08:17 PM
89 F250 7.3 Diesel no start issues Tony Leverington 1987 - 1996 F150 & Larger F-Series Trucks 3 02-20-2017 12:25 PM
Truck Starts, then dies: Also dies while driving RedDevil460 1999 - 2003 7.3L Power Stroke Diesel 9 08-12-2016 07:07 AM
Rough idle no fuel pressure BigBlueX 6.0L Power Stroke Diesel 13 06-06-2016 09:36 PM
85 F250 6.9 diesel won't start fballguy Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 23 03-20-2016 08:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
