6.0l valve cover removal - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 08-11-2017, 02:32 PM
Skidj2x
Skidj2x is offline
Skidj2x is starting off with a positive reputation.
2005 E-Series, as in Econoline, E450 6.0, thomasbuilt schoolbus. 100% stock, aside from a zip tie here or there.
Poor drivability, low ICP pressure codes, and now a no start. Hpop only producing about 125psi at 87% Ipr. Ficm 12v in, 49.7v out, with sync.
Trying to perform air pressure test, but I can't get to the outboard center valve cover bolt on the driver's side. Already removed engine mounts on both sides and dropped engine down so the oil pan is sitting on the frame cross member. No matter how high or low I position the engine, there just isn't enough room to get to that last bolt. Don't have my crackerjack secret decoder ring or a shop manual. So is there something I'm missing, a trick to getting this valve cover off, like pulling the engine out? Like this isn't an in-frame operation?
LowcountryF150
79
03-04-2017 08:54 PM
1972-34ton
07-06-2015 08:31 PM
ericford1984
29
03-14-2012 09:50 PM
shameless
09-27-2011 01:03 PM
troysbowman
1978 - 1996 Big Bronco
10-18-2002 12:08 AM
Quick Reply: 6.0l valve cover removal
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
