Door Glass Question? - Ford Truck Enthusiasts Forums
Old 08-11-2017, 08:58 AM
Crop Duster's Avatar
Crop Duster Crop Duster is offline
Crop Duster is starting off with a positive reputation.
I ordered new rear and side glass from Auto City. The rear glass is close enough to the original Car Lite to work OK. The side glass is dimensionally identical to the originals with the exception of the thickness. The original Car Lite glass is .180 thick while the replacement is .230 thick. Have any of you used the thicker glass with new division bars an felts? I am a little concerned it might be too tight of a fit. And I know what a PITA it is to get all this stuff in an out of the doors. I really don't want to do it twice.
Also I checked with LMC, they didn't know how thick their glass was. I checked with NPD and they gave me their suppliers number and their glass is .230 thick.
Old 08-11-2017, 11:21 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The NAGS (National Auto Glass Society) number for the tempered door glass is 4327T (specify clear or tinted).
The tempered back glass NAGS# is 1052T (specify clear or tinted).
NAGS numbers are what auto glass shops go by.
All the glass for the doors and cab are the same: 1961/66 F100/1100; 1963/69 N/NT500/1000 & 1967/69 F800/1000 because all these trucks used the same basic cabs.
Old 08-11-2017, 11:47 AM
asmith6 asmith6 is offline
asmith6 is starting off with a positive reputation.
I have a set of original door glass if interested.
Would need to verify condition.
Can send images if you like.
Aaron
Old 08-11-2017, 11:50 AM
Thanks ND. When NPD gave me the number to call they said to tell them the part number was 4327T-C which I did. And guy said it was .220 to .230 thick. I don't mind using it if the window will work correctly, but I don't want to have to use both hands to roll the window up.
Old 08-11-2017, 11:57 AM
Glass
Aaron
Thanks, I will keep that in mind. I have 5 originals here but they all have issues.. I was hoping to start out with zero scratches some how a scratch in a glass just bothers me a lot.
Old 08-11-2017, 12:10 PM
6t6merc 6t6merc is online now
6t6merc is gaining momentum as a positive member of FTE.6t6merc is gaining momentum as a positive member of FTE.
The Carlite door glass in my '66 measures .20". My spare window glass - with no markings - measures .24". The latter moves fine in the parts door, and the glass runs are in pretty good shape.
Eric
Old 08-11-2017, 01:00 PM
Glass
Quote:
Eric
Thanks that gives me hope that they will work OK.
Old 08-13-2017, 06:47 PM
TxStang2010 TxStang2010 is offline
TxStang2010 is gaining momentum as a positive member of FTE.
0.050 is not a huge difference for glass fitment of a moving window , the felt in the tracks should easily compensate for that . I'm sure back then Ford had a tolerance spec for that as well since they have a tolerance spec for everything else .
05 Escape Rear Glass Won't lock ? creen Escape & Escape Hybrid 5 12-19-2016 01:45 PM
Vent glass help! F&M 1961 - 1966 F-100 & Larger F-Series Trucks 5 11-01-2016 05:14 PM
2008 Escape rear side glass, (pass) window replacement MtnMan6114 Escape & Escape Hybrid 3 08-23-2016 07:19 PM
VENT WINDOW SETTING TAPE jvmcc 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 03-10-2016 07:39 PM
Glass Question Tempered VS Laminated Scotty's 52 F3 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 01-15-2016 09:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
