Wd 40
Old Aug 9, 2017 | 09:54 PM
F1fiddie's Avatar
F1fiddie
Wd 40
Can i use wd 40 to clean stuck on brake dust from my rims?
Old Aug 10, 2017 | 09:53 AM
alloro's Avatar
alloro
WD-40 is not a cleanser and any residue left behind will be a dirt magnet. Use polishing compound if you need to clean off suborn brake dust and dirt.
Old Aug 10, 2017 | 09:55 AM
Tedster9's Avatar
Tedster9
WD40 is just Kerosene in a spray can, basically. If it works for you, sure why not.
Old Aug 10, 2017 | 10:22 AM
Olds64's Avatar
Olds64
Once you clean the rim with car soap and water use a good quality metal polish to get a bright shine. Here is one I use now that was suggested to me by a gent that had been doing auto body for 50+ years. It works great!
Amazon Amazon
Old Aug 11, 2017 | 02:55 PM
alloro's Avatar
alloro
Not sure where you came up with that notion but it's not correct.
https://en.wikipedia.org/wiki/WD-40#Formulation
WD-40's formula is a trade secret. To avoid disclosing its composition, the product was not patented in 1953, and the window of opportunity for patenting it has long since closed. WD-40's main ingredients as supplied in aerosol cans, according to U.S. Material Safety Data Sheet information, are:
50% "aliphatic hydrocarbons". The manufacturer's website claims this ratio in the current formulation cannot accurately be described as Stoddard solvent, a similar mixture of hydrocarbons.
<25% petroleum base oil. Presumably a mineral oil or light lubricating oil.
12–18% low vapor pressure aliphatic hydrocarbon. Reduces the liquid's viscosity so that it can be used in aerosols. The hydrocarbon evaporates during application.
2–3% carbon dioxide. A propellant which is now used instead of the original liquefied petroleum gas to reduce WD-40's flammability.
<10% inert ingredients.
The German version of the mandatory EU safety sheet lists the following safety-relevant ingredients:
60–80% hydrogen-treated heavy naphtha (a petroleum product used in wick-type cigarette lighters)
1–5% carbon dioxide
It warns of the product's high flammability and the risk of irritation to human skin when repeatedly exposed to WD-40. Nitrile rubber gloves and safety glasses should be worn (ordinary rubber disintegrates if exposed to petroleum products). It also mentions that water is unsuitable for extinguishing burning WD-40.
In 2009, Wired published an article with the results of gas chromatography and mass spectroscopy tests on WD-40, claiming that its ingredients make it resistant to freezing.
Old Aug 11, 2017 | 06:13 PM
Tedster9's Avatar
Tedster9
Embrace the power of "basically".
Old Aug 13, 2017 | 04:31 PM
F150Torqued's Avatar
F150Torqued
Hummm. I use the stuff for cologne.
Old Aug 13, 2017 | 05:08 PM
Tedster9's Avatar
Tedster9
That's what Hoppes #9 is for. Drives the ladies wild.
(Ballistol will attract them too aka "WTF IS THAT SMELL!!?")
Old Aug 14, 2017 | 06:42 PM
1saxman's Avatar
1saxman
I buy WD-40 by the gallon and use it for a lot of things but I would never spray it on wheels as it would get on the brake rotors. Use a wheel/tire cleaner and a soft bristle brush for the best results, and rinse off as directed. If you use anything on your tires, avoid getting it on the wheels and brake rotors. I like spraying the tire shine on the soft bristle brush and putting it on the tire that way.
On wheels with a glossy finish; use any regular car wax after cleaning and drying.
Drying after washing the car; have you ever seen anything more ridiculous than the vacuum cleaner with the hose on the exhaust end, sold as a 'car drier'? Of course it works great, but any vacuum cleaner or Shop Vac with a blow fitting can do the same thing!
Old Aug 15, 2017 | 12:00 PM
StarFox's Avatar
StarFox
I always used my 200mph Toro leaf blower to dry my motorcycle after washing. Too many nook and crannies to dry any other way. It works great on the truck too....
Michael Ward
1997 - 2003 F150
Jun 30, 2019 08:35 PM
Bruker
General Automotive Discussion
Nov 17, 2009 09:47 PM
danw64
May 2, 2009 11:36 PM
rjd75
Mar 24, 2008 03:20 PM
elite64a
2004 - 2008 F150
16
Jun 23, 2006 11:18 AM
