My 89 E150 runs hot
My 89 E150 runs hot
She plateaus at 215° and though it doesn't spit any fluid out it concerns me. Here's some background on my van:
Just had the engine rebuilt. (385 series-it was a 427 truck engine before the machining and Ran hot)
installed engine oil cooler-approximately 30" x 30" cooler size with 3/8 line (ran hot)
Replaced 3 core copper radiator with 2 core aluminum radiator-has 1/4 inch or 5/16 tubing (can't recall exactly but manufacturer claims it should run 30% cooler than a 4 core copper radiator, Ran hot)
Replaced stock water pump with high flow Edelbrock water pump (runs hot but now plateaus at 215°)
Also, C6 transmission on its own cooler (12" x 16"cooler size)
ANY suggestions on keeping this thing cool? I have read through all your forms concerning overheating vans and have tried many tricks including boring a quarter inch hole in my 160° thermostat. Radiator cap has been swapped out several times in hopes it was defective (same result). And the radiator hoses are flex style hoses and cannot collapse.
Thank you for any and all help.
PS this problem doesn't exist on days cooler than 100° which is a short window here in the Southwest
Yes, stock exhaust manifold's and not that it should matter but I did forget to mention it has a cam for towing but beyond that the rebuild the stock. Other aftermarket add-ons is Edelbrock intake with 650 Edelbrock. If you think exhaust manifold's will fix it I will definitely try that as of arty have over 10 grand in the rebuild so what's a couple more hundred. Is there a recommendation for a good heavy header that is designed to go into a van?
I agree with vertex that I wouldn't worry about 215 if its not going higher or the caps not venting. As to the exhaust, I myself, never ran into any bad manifolds. But I was told they had some that caused problems. Since you said it ran warm before rebuild, and I assume timing would have been checked when you set the rebuild up, it should be something that didn't change when you rebuilt. Are you sure it is going to 215? Not just an off gauge or sending unit?
Any tricks for removing all the air out of your cooling system? New high flow waterpump was supposed to minimize this but apparently this is another issue as my factory electric temperature gauge ran normal today and the aftermarket temperature gauge ran to 225, puzzling, yet nothing bubbled out or over. Waiting on a new gauge I ordered will let you know results when that is installed. Still looking for good aftermarket headers but none of them look conducive for a van set up. Thanks again.
By the way: why would some recommend drilling a quarter inch hole in your thermostat and others would say no way?
