04 escape rattle/clunking
04 Escape 2wd 6 cylinder 170k miles. Intermittent clunk/rattle sound when hitting bumps while going straight and especially turning right. I felt a slight bumping in passenger side floor board. Inspected everything. All looks good and tight- no signs of loose hardware, worn ball joints or tie rods. Only thing I noticed was a slight rub mark (missing paint) on the lower control arm under the sway bar on drivers side. And noticed the rear bushings on the control arms are tearing. Not collapsing but with the tire removed and suspension hanging at full droop you can see tears in that rear bushing on both sides. We painted the arm and sway bar in the rubbing location to see if it makes a mark there again after driving it a few days. Question is do you think that the rear control arm bushings could be allowing enough movement to contact the sway bar or make the noise? The bolts are tight.
Has newer Moog struts and newer swaybar end bushings, possibly sway bar hold down bushings too- (they look pretty good).
Msp541
08-09-2004 02:49 PM
