F-250 vs F-350 --- so close!
I always go 250. My state charges by GVWR for registration which can make a big difference over the life of the vehicle. The differences (which are also my understanding of the only ones there are) you note can be overcome by installing air bags which I'm going to do anyway. So for me a 250 + airbags = 350 capability with lower cost. The only way I'd go 350 is if I were going for a dualy which I would only do if I were going to buy a much larger trailer.
Originally Posted by TX03RUBI
If this is your plan the be sure and get the HD 250 with the upgraded rear axle. It'll give you 350 equipment with a 250 sticker to keep registration down.
I have been looking at this same thing...F250 or F350? I tow an 8500# Aisrtream with a tongue weight of 880#'s. NO plan to go any larger and NO plans for a fifth wheel (been there done that). Seems the F250 Gas with the 4.30 is all I really need. Is there much of a difference in the ride? Does the F350 ride a little harsher than the F250 due to the stiffer springs? Not purchasing for 18 months but....doing as much research as I can now.
Hi guys,
I need a new 2017 truck quick and am on the fence about whether to go with the 250 or the 350. Afaik the only differences are these:
F-350 - bigger rear spring block
F-350 - 1 extra rear leaf (?)
F-350 - slightly stiffer front coils (optional on 250)
F-350 - slightly bigger center section in rear diff
F-350 - a little more max load capacity
F-250 costs $3k less!
Drivetrains are both the same. Front diffs are the same. Bodies are the same. I can't confirm but suspect the brakes are the same too...
The drivetrains vary:
- F250 with gas engine is fitted with 6R100 TorqShift G and Ford Sterling rear axle
- F250 with diesel engine is fitted with 6R140 AT and Ford Sterling rear axle
- F250 with diesel + HD tow Pkg is fitted with 6R140 AT and Dana M275 rear axle
- F350 with gas engine is fitted with 6R140 AT and Ford Sterling rear axle
- F350 with diesel engine is fitted with 6R140 AT and Dana M275 rear axle
- Gas and diesel engines offer different axle ratio options
F250 max GVWR is 10K lbs., and is probably "paper limited". Max F350 SRW GVWR is 11,500 lbs. Don't know about the front springs.
My recollection is that comparably equipped, the price difference is quite small.
HTH,
Jim / crewzer
#29
In my county of fairfax Va. Personal Property Tax would have been on the 17 350's over 10,000Lbs, 3400.00 first year, No tax break. My 250's 10,000 and under is 694.00 with the Tax relief. Thats 2706.00 per truck. It was a no brainer. That does get lower each year. The badge on the front fender means nothing to me. The 250's make just as much money for me as the 350 would.
#30
