10.25 pushed to the max. What's next?
The last break was because of the transmission I'm pretty sure. I burnt 2nd gear so I programmed it to shift from 1st to 3rd and then lock the converter at 50 percent throttle . I was full mash at the shift and it banged into 3rd and locked same time. 90 feet and it broke a dana 80 shaft. It usually breaks on the far end when the sled gets heavy and full power. I run street pressure of about 65psi.
The truck looks planted with not much wheel spin. I'm no expert but a friend of mine pulled for many years, to bad he expired a few years ago or I could ask him.
Hopping is bad as well as no wheel spin or a down shift at the end of a pull. Can you run a Super Single in the rear? Locker in the front? She is laying over on the right front, you could address that also within the rules of course.
I would want to come out of the hole with wheel spin either by gearing or tires, she will hook in the first 50 feet where you take advantage and get the sled up to speed.
I know the guys around here block the frame, it is not locked, just allows 1 inch of travel like a bump stop.
I can't hold it. The brakes won't hold it. Creeps. 2 different front brake setups up front and multiple rear axles and now has a dodge cab and chassis dana 80 with big brakes. The stall is a 2600 from suncoast. Street mod class. Not much enforcing any rules around here. Just for fun really.
I would up the stall and figure out a way (not knowing your set up) to unlock the converter before the end of the run where you stop. Smaller tire or lower gear perhaps but you need a full head of steam coming out of the hole or with in 20 ft of the start. Seems to me, lol what do I know, the sled weight is transferring faster than your lighting the turbo and getting up to speed.
I can program the tranny to do whatever needed. It's a pcs controller. I have chromoly shafts coming in next week and a new Kevlar 2nd gear band coming tomorrow. There is a pull next weekend I think. I'll get it together and we if anything changes. I'm putting weight in the bed which I know contributes to the breakage. Truck only weights 7300 without the added weight
You need the weight as far to front as you can over the front axle. Not sure what engine we are dealing with but my 6.0L is a 2200 stall from SunCoast for the strip, not bad for the street so you would be even higher to pull.
Move what weight you can to the front. You could also use a tie down shock on the left front to help slow it down from transferring to the right.
For line holding, what kind of brake booster were you running? Stock vacuum or hydroboost? I ask because there were factory F-superduties with hydroboost brakes all the way back to 87. They are far superior to the vacuum brakes. Last I checked, Rock auto had NIB motorcraft hydroboosters for sale.
I know guys running hydroboost that can lock up their 40" tires on pavement
It's been a while and I've learned some since my last confession.
I took the old truck drag racing and to a few more pulls. Drag racing is way easier on parts. Heat seems to be the only enemy.
On the street in 4 high I can hold the boost back to a little over 20lbs. 2wd or 4low and it creeps. The Chevy brakes I have on the front seem to be way stronger then the old ford setup. But 4low and even with a 2600 stall speed it's hard to hold it back.
I did end up getting some weights for the front hanger but haven't used them at a pull yet. The last pull I went to I had the drag race tune in the tranny and it got into overdrive and locked the convrtor. It snuffed the flame and fell short.
5.4L to Freedom
1999 to 2016 Super Duty
27
11-29-2009 03:33 PM
65'f1004x4conver
03-04-2007 12:26 AM
ovaltrack
General Automotive Discussion
05-23-2006 09:46 PM
