Is 1964/65 F100 as daily driver a challenge?
For those of you driving a 60's model F100 as a daily driver, is it a challenge to fix/repair when things go wrong?
I currently drive a '94 F-150 every day. I'm considering selling it and purchasing either a '64 or a '65 (going to look at one of each this week). The reason I drive a '94 is that parts are easy to find (junkyard/autoparts store) and they are straight-forward to fix.
I never see anything older than 70's models at the junkyard. Are parts hard to find for the pre-70's models? Also, what would you say is the biggest challenge of having one of these models as your daily commuter (lack of A/C, repair cost, etc.)?
Just hoping for some advice before I decide to take the plunge on this.
Thanks!
Thanks!
I am currently fixing my 1961 unibody to be my daily driver. It is all original. I have replaced the entire brake system including using stainless lines from inline tube. Cost around 400 bucks. Did it exactly as original. I replaced the clutch kit and had the flywheel resurfaced. Cost about 250. Replaced the rear transmission seal, oil pan gasket, oil pump, u joints, new rims and tires, radiator boiled and repaired, and new waterpump.
I had to have my waterpump sent off to be rebuilt and is going to be sent back.
I got everything through oreilly auto parts. Most things took half a day to a full day to get.
When I am done, it should be problem free for a long time.
In the meantime I am driving my father's loaner 66 f100 flareside that is in very rough shape, everyday. It doesn't miss a beat.
I have always had a 65 66 f100 to drive my whole teen and adult life. Never hesitated to go anywhere I wanted.
A 64 is going to be straight axle like mine. You may want to look for a 65 or 66 with twin I beam. Many easy upgrades can be made to them for steering and braking.
Power steering instead of manual. Power brakes and disc conversion instead of manual.
brepei
02-22-2016 05:23 AM
HardFordCore
12-02-2008 10:45 PM
