Another rear window thread but with a twist - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco
Old 08-05-2017, 12:31 PM
ronjeremy6's Avatar
ronjeremy6 ronjeremy6 is offline
ronjeremy6 is starting off with a positive reputation.
95 EB 5.0. Rear window is either working flawlessly or not moving at all. When it's not moving the dome light dims when I'm either on the dash switch or key at tailgate. My son drives the truck and tells me sometimes it gets stuck down and sometimes up. Motor was replaced in 2013, and I replaced the right side roller in 2015. Left side was drooping and I found the roller to be crushed into an oval instead of a square.
This past week he was at the beach, so I drove the truck to try to mimic the problem he described. Monday, didn't budge. Tuesday morning, hit the dash button, got few pops and the window went down nicely! Immediately lubed the tracks and all moving parts (except for the rollers). Wednesday and Thursday, business as usual. Then Friday, stuck in the up position.
Anyone got ideas? Of course I first thought electrical, but the dimming dome light tells me I have power at both switches. The pops I heard tell me mechanical, but where do I start? Please help! We have brought this truck back to 100% original and the back window issue is owning me.
Old 08-06-2017, 02:58 AM
grumpin's Avatar
grumpin grumpin is offline
grumpin is gaining momentum as a positive member of FTE.
My driver's door was doing that and I tapped the motor, while holding the switch and has been working ever since.
Will have to replace that motor soon.
Old 08-06-2017, 10:57 AM
86fsbronco's Avatar
86fsbronco 86fsbronco is offline
86fsbronco is starting off with a positive reputation.
Have you checked the wiring between the tailgate and bed? I had a similar problem with my 95 ended up being a broken wire.
Old 08-06-2017, 03:47 PM
ronjeremy6's Avatar
Quote:
I haven't checked this yet. Are these the wires in the left rear quarter behind the trim?
Old 08-06-2017, 04:05 PM
schwim's Avatar
schwim schwim is offline
schwim is starting off with a positive reputation.
My guess would be that the motor is binding due to the sacrificial pucks inside being worn to the point of jamming between the gears. My window motor behaved identically to yours when my pucks needed replacing.
Old 08-20-2017, 04:08 PM
ronjeremy6's Avatar
Quote:
Might just put in a new motor, it started working again for a few days now it's stuck again. Did yours stick in the up and down position or only up?
Old 08-20-2017, 08:10 PM
schwim's Avatar
Quote:
It was in both positions. It didn't follow any pattern. A lot of people simply forego the rebuild to go straight to a new motor. They don't cost that much money and it's more convenient/less hassle.
Old 11-25-2017, 07:08 PM
PoorTrailerTrash's Avatar
PoorTrailerTrash PoorTrailerTrash is offline
PoorTrailerTrash is starting off with a positive reputation.
If you are still having this issue it could be a corrosion issue in the wire connections. I fought mine for about a month until I noticed connectors had a blackish coloring. I sanded & wire brushed all contacts (inner & out) until they were that brass ccolor again them put dielectric grease on them as well. 2 years trouble free now.
Old 11-25-2017, 08:58 PM
Tim Hodgson's Avatar
Tim Hodgson Tim Hodgson is offline
Learning slowly...
Tim Hodgson is a splendid one to beholdTim Hodgson is a splendid one to beholdTim Hodgson is a splendid one to beholdTim Hodgson is a splendid one to beholdTim Hodgson is a splendid one to beholdTim Hodgson is a splendid one to beholdTim Hodgson is a splendid one to behold
Couple of thoughts:
1. I replaced the delrin pucks in all three windows as mentioned by schwim. Time to do that if it hasn't been done yet for sure;
2. One thing that hasn't been mentioned yet, is the safety switch on the driver's side tailgate latch. You know how you can't roll up or down the window when the tailgate is down? Well there is a saftety switch in there which must be closed to complete the circuit for the switches to operate the motor. A couple of years back, I thought I had an "electrical" problem because my rear window would get stuck, but it turned out to be a "mechanical" problem in that the driver's side gate latch was not adjusted properly and, thus, was not engaging its safety switch.
Pretty much have to take the inside access panel off, figure out how to engage the switch via the tailgate catch with the gate in the horizontal position, then have someone "raise" the window horizontally while you are supporting it with your hands and then let it lay flat at a stress-free angle on one or more padded bar stools while you get in there with a mirror and clean up the contacts and everything and reposition the switch so it will engage when the tailgate latch is locked in the vertical upright position.
Old 11-26-2017, 07:18 PM
Black Ford XLT's Avatar
Black Ford XLT Black Ford XLT is offline
Black Ford XLT is gaining momentum as a positive member of FTE.
Fought the rear window problems for years, I finally had enough, in doing searches I took Steves advice and used two relays and rewired mine. Finally I can use mine with out key in ignition and it did away with the resistive factory wiring. Actually my rear key switch was not working before I rewired .Key switch works great and no more problems. Good luck TR
2005 - Does GEM control the Dome Light? zmanmike 1999 to 2016 Super Duty 13 02-05-2018 02:19 PM
how to disable passenger window switch bigtexan99 1999 to 2016 Super Duty 11 09-13-2017 09:46 AM
Door Ajar Light Problem- IT AINT THE SWITCH! Critterhunter Ranger & B-Series 38 05-26-2017 02:05 PM
window roller in '56 f-350 gusThe56f-350 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 06-29-2016 12:13 AM
question about stock 53 F100 window regulator jvmcc 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 03-11-2016 04:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
