Ebear, It looks like you are using a Ford gas pedal and throttle cable? Was that what you ended up using? I have one from the 85 F 150 I got the 300 6 out of and would like to use but it seems too big. Nice job you're doing. Drew, yours looks great. Did you change your plans and use the purchased brake pedal? The one you bent up looked good to me.
Drew that looks awesome, thanks for the pictures that's going to help a lot. I've been looking over the different pedal ratios to be honest I find it a little complicated. I'll look up that "wag" ratio. Very nice work simple but very effective, even the brake lines to the master are nice and clean! Thanks again
Zac
I purchased the custom gas and brake pedals just to get a nicer look and the gas pedal put the linkage and cable under the floor rather than going out through the firewall.
