1953 F100 Build
1953 F100 Build
I picked this truck up 9 months ago. Relatively good metal, no engine or trans.
I am building a 1991 5.0 Mustang HO with AOD tranny. Motor will be refreshed but basically stock at 225 HP. I have redone the springs. In the rear, I flipped,the top spring, removed leaves, raised forward bracket, rebuilt hangars. In the front, I replaced leafs and moved axle forward about an inch. Also changed out front axle to a 3 inch drop. Total drop should be around 5 inches.
As for body, I took each panel and made repairs and then painted with two part epoxy to wait for final painting. Currently reassembling 5.0 motor and going to carburation to keep things simple. Trying to address correct oil pan for build so it fits the first time. Planning on tilt hood, considering matte red to be a bit different. Leaning towards ABS interior panels with OEM seat.
Ford 1953 F100
Ford 1953 F100
Looks like a great project. Let's see some pictures of what it looks like now. :-)
Sounds like your making good progress. Would love to learn from what your doing! Do you have the complete donor car or are you piecing it together. How are you working your brakes? Firewall master, under floor.
Thanks
Zac
Thanks
Zac
cdl2374
31
01-21-2017 09:39 PM
pappacrunch
66
08-20-2016 09:23 PM
JDBeck23
11-12-2012 11:05 AM
Rokcrln
05-02-2008 08:51 PM
