Time to eat some crow. I had boost leaks. Listen to people on the forum
#31
#34
#35
I am assuming if the 6.0 oem fits aftermarket for the 6.0 should also work? were you looking at just 7.3 aftermarket? and or 6.0 also?
I will not be getting anything anytime soon since the sub $100 stock 6.0 option with boots/clamps fell thru.
#36
#37
Turbo surgery. Snapped one bolt off in the old exhaust housing glad I am not using it. Had to drill out the wastegate rod eye. It would not fit the banks 1.0 housing. I also drilled a 1/2" hole in the divider to help equalize pressure when the wastegate is open.
Installed the Riffraff plenum inserts and tbolt clamps.
Map sensor stopped at 25 Something minus 14 something baro. So about 40 absolute. I thought it went higher before but that is what I saw. No leaks. Just realized I didn't hook up the ccv back up. Need to do that tonight
#40
very slight difference on the bottom. Not bad at all. Up top pulls better.... Much better.. Same boost or a touch less but more power with less back pressure. At least according to the sotp dyno. Only drove it around enough to warm it up then about 10 minutes.
I doubt I'll be bothered by the delay down low daily driving it. Not as bad as I expected. I did notice a few more puffs of smoke here and there especially if I shifted early. Delaying a few hundred rpm made it better. I'm only talking a little bit of smoke not like it is bad but I'd prefer none. Turning at an intersection and leaving it in 3rd when I should have been in 2nd type of deal.
Sparkplugless
24
08-09-2018 06:30 AM
bigreentruck
04-08-2015 12:35 AM
UP_There
12-04-2008 06:10 PM
makomaker
06-01-2008 03:55 AM
