Aftermarket Gauges
Mike - Good point. I've actually considered having one temp gauge in the block and one after the 'stat just so I would know that the 'stat is working properly. In other words, if it doesn't close properly the two gauges will read pretty much the same at all times. And if it doesn't open properly there will be a difference in the two.
Measuring coolant temp accurately when the truck is cold, in not that important. It's knowing if the truck is getting too hot - that's important. So installing the aftermarket temp sensor in the thermostat housing is perfectly acceptable place (if no other location is available). IMO.
Another option may be to install a tee-fitting in the heater hose that has a NTP port. https://www.summitracing.com/parts/atm-2280/overview/
I have used fittings in the heater hose. That works well
Maybe it's finally time to split the forum into two separate entities:
1) Ford Truck Enthusiasts Who Trust the Factory Gauges
2) Ford Truck Enthusiasts Who Do Not Trust the Factory Gauges
Moderators, can you set up the two new forums, please? I don't see any other realistic options.
That is the plug I am thinking may be a spot for another temp gauge??
I tore out the aftermarket cruise that the PO put in and I already have a hole so I am thinking that two gauges (prob 2in) on either side will fit nicely with my trim. Cant go much bigger because there is brace going down the center of both sides in the back.
I don't think that hole gets into coolant. I believe the coolant on a Windsor only runs straight across the front and the back of the intake manifold from side to side. So only ports in that area will work.
As for the placement of gauges, those spots will work well. They are dramatically more visible than down where I have mine. I think ctubutis put his there, so he may have a pic in his albums - if his pics are still intact.
What stuff I have in any FTE albums & galleries I don't know, but that's small, single-use stuff (in general).
ImageShack was the first image-hosting provider to do what PhotoBucket is now doing - dropping those customers who don't pay.
I've been burned twice now and am in no hurry to do it again.
Another place that might work for you is the left pillar. There are gauge pods available
like this https://www.summitracing.com/parts/g...rd/model/f-150
However, the earliest I can find is for a 1987. I have one now (a single pod) for an '87+ year truck, and it is not an exact match to the 80-86 pillar shape, but it's close enough that is not obvious.
People have used Bondo & paint to meld everything together if you want to go through the effort.
#28
Ok..thanks..
No other port on the other side..there is one on top of the thermostat housing so I think that is where I will put it.
Looked at a good place to put my oil pressure sensor, and there is already a tee coming off the engine..on top of the tee is the stock sending unit (that I just replaced) and I'm not sure what is coming straight off it. Anybody got an idea? I put oil pressure sender into autozone and two components came up: "oil pressure sender" and "and oil pressure safety switch." So I was thinking maybe it is a safety switch. However the switch they showed had a similar setup to my oil pressure sender-it takes a boot. What I have coming straight off the tee has two wires-pink and white. Thanks for all the help.
#29
#30
