Valve Cover Gasket Replacement...Any Tips?
Hi All,
I'm planning on replacing the driver side valve cover gasket on my truck this weekend. It is making a mess.
I'm using new Felpro gaskets. Beyond making sure the surfaces are clean/dry and a putting small dab of RTV at the timing cover joint is there anything I should look out for?
Torque from the middle out, 8 ft/lbs.
Thanks
Thanks
tealboy1
12-26-2008 11:43 AM
