1995 F-250 7.3L - New to Group - Ford Truck Enthusiasts Forums
Old 08-01-2017, 09:02 PM
Oldschool57's Avatar
Oldschool57 Oldschool57 is offline
Oldschool57 is starting off with a positive reputation.
Hello,
I wanted to introduce myself to the group. I like turning a wrench and I'm still learning about the 1995 F-250 7.3L that I recently picked up. She has some wear on her, 280K with a 5 speed manual. The was rebuilt at some point.
I have noob question. I realize that the owners manual from 1995 lists the type of fluids recommended to maintain the vehicle. 22 years later, do you guys recommend other fluids?
Engine Oil - Shell ROTELLA T5 (Synthetic Blend) 15W-40 with 1 quart of Lucas
Oil Filter - Ford Motorcraft
Fuel Filter - Ford Motorcraft
Air Filter - Ford Motorcraft
Manual Transmission - MERCON 5 / Mobil 1 ATF (Synthetic)
Clutch Fluid - Open to suggestions
Rear End - Ford Friction Modifier & 0w-140 gear oil
* No Gasket on rear end, use Motorcraft GRAY silicone
Brakes Fluid - Open to suggestions
Power Steering Fluild - MERCON 5 / Mobil 1 ATF (Synthetic)
Coolant - Open to suggestions
What did I miss? What do you recommend?
Looking forward to being part of the community!
Old 08-02-2017, 07:46 AM
fordman67's Avatar
fordman67 fordman67 is offline
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
Quote:
Originally Posted by Oldschool57 View Post
Hello,
welcome first off!
Second, leave the additive out of the oil . the high pressure oil system won't like that and its just not needed. Coolant, search fleet charge with sca.
Old 08-02-2017, 08:33 AM
Quote:
Originally Posted by fordman67 View Post
welcome first off!
Done! Picking up some coolant today, thanks again.
Old 08-02-2017, 09:16 AM
Jarrett Campbell's Avatar
Jarrett Campbell Jarrett Campbell is offline
Jarrett Campbell is gaining momentum as a positive member of FTE.
Make sure you get the SCA additive for the coolant. From what I have seen, it takes 3 bottles of additive to get the SCAs up where they need to be.
Whoops, 67 beat me to it.
Have fun with the new truck!
Old 08-02-2017, 09:26 AM
madpogue madpogue is online now
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
FleetCharge anti-freeze is pre-charged with SCA, as 67 said. But be careful, the labeling on the full-strength vs. 50/50 diluted is VERY similar. Buying 50/50 is just an expensive way of buying distilled water.
Clutch and brake fluid, DOT 3 is fine. But I sure wouldn't touch the clutch hydraulics if they're working. You're opening up a can of potential pain, bleeding the system.
4x4 or 2WD? Are you sure the rear diff is LS?
Oh, and yeah, welcome.What was rebuilt?
Old 08-18-2017, 09:04 PM
The F-250 is a 2WD with a 5 speed manual
The engine was rebuilt prior to my ownership, it runs really well.
Thanks for all the advice, I have purchased the proper coolant now!
ArmyLifer's Excursion maintenance/upgrade thread ArmyLifer Excursion - King of SUVs 193 Today 01:45 PM
Best Exhaust Bolts To Use ? pchelp 1967 - 1972 F-100 & Larger F-Series Trucks 21 06-18-2017 12:55 PM
Transfer case fluid, Mercon V will destroy the transfer case?? Skauber 1997-2006 Expedition & Navigator 18 04-02-2017 08:45 AM
Ford 4R100 transmission flush fluid recommendation dntsdad Modular V10 (6.8l) 12 06-21-2016 12:19 AM
Mobil-1 ATF for 4R100 kawika 1999 - 2003 7.3L Power Stroke Diesel 28 03-02-2016 09:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
