Injectors...favorite TOOLS?
  #106
Old 11-20-2017, 09:16 PM
Colorado350's Avatar
Colorado350
Colorado350 is offline
Originally Posted by brian42
I've been using these for most of the years I've had my truck:
http://www.dieselsite.com/19995-2003...fter12198.aspx
http://www.dieselsite.com/1999-20037...erbootkit.aspx
The spider-to-CAC tube boots are more than long enough. When I installed mine I fully seated the boot against the ridge on the spider and adjusted the CAC tube to be in a "natural" position before tightening the clamps. IIRC the boot is over the ridge on both my CAC tubes. I've only had one "blowout" in 8-ish years and that was at near WOT merging onto a freeway (turned out to be a loose clamp).
Happy anniversary. Looking forward to hearing good news on getting it started. I'm getting closer to that point also and am dreading that it will not turn over with all the work I did and it being down so long.
Originally Posted by ExPACamper
How long are your spider to CAC boots? These are about 4" (could be 4.25")..
Here's the measurements of the Dieselsite CAC & Plenum Boots.
  #107
Old 11-20-2017, 09:21 PM
ExPACamper's Avatar
ExPACamper
ExPACamper is offline
That top one is about what I saw on the RRD boot. Thanks
Here's what we're going to try. A buddy put a rough bead and a friction dot under where the clamp will sit.
  #108
Old 11-20-2017, 09:26 PM
ExPACamper's Avatar
ExPACamper
Still no HPO, ICP only gets to 156psi. IPR climbs all the way up to about 94% while cranking.
The IPR is about a year or two old, Ford OEM.
I'll have to go over the connections and wiring later this week and see if I can figure it out.
  #109
Old 11-20-2017, 09:31 PM
ExPACamper's Avatar
ExPACamper
BTW, those look like some really tough boots. Thanks for the pics and info
  #110
Old 11-21-2017, 04:33 PM
white Buffalo's Avatar
white Buffalo
white Buffalo is offline
How old is the ICP sensor? Did you try staring her with the ICP sensor unplugged? It's gonna take a while to start , gotta get that oil back into the system.
  #111
Old 11-21-2017, 05:37 PM
ExPACamper's Avatar
ExPACamper
ICP is about 3 yrs old and I haven't tried it with it disconnected yet.
When I get back I am going to change the oil (enough cranking to get rid of any contamination from cleaning cup and previous failure, I think), fill hpop reservoir, remove ICP and fill that head, then crank a bit, then unplug ICP.
If that foamy work after a reasonable time, I'll move on to a Cody test and take it from there.
Sound like a reasonable plan?
  #112
Sous's Avatar
Sous
Sous is online now
Received 4,426 Likes on 2,834 Posts
Especially if the heads were empty of oil. I have seen some FTE'ers fill the head rails from the ICP sensor port and the HPO port, but it is not required.
EDIT: You were typing the same thing I was at nearly the same time. Let us know how it goes.
  #113
Old 11-21-2017, 05:42 PM
ExPACamper's Avatar
ExPACamper
I'm typing on my cell from a hotel room out of state. I am not setting any speed records, lol
Thanks for the suggestions, fellas
  #114
Old 11-21-2017, 09:33 PM
white Buffalo
How old is the IPR John? If it was me I would put a new IPR & ICP in with new injectors. But that's just me.
Also, turn the KOEO for 20 seconds, do it three times. Make sure you get the fuel pressure up.
Its been a while, I can't remember - did you pull the Riff Raff fuel kit off and put it back to stock?
  #115
Old 11-21-2017, 09:39 PM
white Buffalo
Also, since you have Hydra you can put it in the no start setting and crank her that way for a bit first & get the oil moving without starting.
  #116
Old 11-21-2017, 09:41 PM
white Buffalo
Oops, IPR is relatively new. Don't listen to me on that one.......
  #117
Old 11-22-2017, 10:11 AM
ExPACamper's Avatar
ExPACamper
Thanks for the advice, Rich.
The IPR is about 2 yrs old. Remember the breakdown? I used a lifeline call to Tugly, was rewarded by driving over an hour each way and overpaying at a dealership, LOL. But it got my Excursion home, so it wasn't all bad
I am going to go through it carefully from the oil side, changing it and the filter, filling what I can, etc.
The plan is to get on it tomorrow. It is supposed to be pretty cold here now through tonight, about 35* warmer tomorrow
Hope you got a good harvest! Good to hear from you again
  #118
Old 11-22-2017, 08:42 PM
white Buffalo
Damn, wish I was closer to help you out!
  #119
Old 11-22-2017, 09:07 PM
ExPACamper's Avatar
ExPACamper
But then my Excursion would be finished and working smoothly. Where's the fun in that? LOL.
  #120
Old 11-26-2017, 05:00 PM
carl2591's Avatar
carl2591
carl2591 is offline
I was looking at Rosewoods site and he was saying on injectors with "high miles" more so are in need of Plunger & Barrels and nozzles as well. What is considered a high mileage truck.
Mine is at 180K currently and seems fine but know I may need in a couple years to have injectors gone through and replace cups getting ready for full time RVing. expect to only have maybe 190K or so .. truck is not driven much during the week.
Same here John. My O-rings looked alot worse than your did when we replaced injectors on the Ex 3 years ago at 220K and I wasn't loosing oil like you are experiencing. I'm still confused on where the oil is going bud.
Check out this write up from Dave at Swamps Diesel.
https://swampsdiesel.com/files/7.3LI...Diagnostic.pdf
If it were me I would strongly consider sending them off to Jim at Rosewood Diesel (C******, Ohio) for a $500 stock rebuild. Check out his prices on:
Rosewood Diesel Shop
He also has a DIY kit.
Then I would pull the turbo off and see what is going on there.
Quick Reply: Injectors...favorite TOOLS?
