Cat Scale Weights and Weight Distribution
#46
#47
In your first post I think your A,B,C descriptions at the bottom are jumbled as the weight slips are labeled Weight carrying, WDH and Vehicle, I think A & B are switched...?
To CORRECTLY calculate the actual Tongue Weight you want to subtract the unloaded vehicle drive axle weight from the Weight Carrying drive axle weight, 4820 - 3700 = 1120. Now take that answer and subtract the amount of weight lost from the steer axle on the Weight Carrying ticket, the drive axle is carrying the tongue weight PLUS what was lost from the steer axle. 3680 - 3360 = 320. Now subtract the lost steer axle weight from the total drive axle gain, 1120 - 320 = 800. That is the actual tongue weight of the trailer, 800lbs. So with a total trailer weight of 6100lbs that 800 is about 13%, right on target for a TT tongue weight. And well within the capacity of the 1000lb spring bars on your hitch.
Don't we also have to factor in the 80 lbs. transferred to the trailer axle(s) into the equation (from 5300 to 5380)? Or, did I miss that somewhere (entirely possible...)?
Regards,
Jim / crewzer
#48
No Jim, the TW calculation only uses the truck solo weight and the truck with trailer but without WD engaged weight. The combo weight with WD engaged weight is where that extra 80lbs shows up on the TT axles as well seeing the 240lbs that has been moved back onto the steer axle.
itguy08
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
70
03-20-2014 11:43 PM
Domino
02-24-2008 10:05 AM
