Best chip mods for 7.3l 2002
Now as far as price goes, again it's gonna depend on your intended use for the truck. A few examples would be if your gonna leave your truck with stock injectors and turbo, but add a Tuner and maybe a turbo billet compressor wheel and some slight fuel mods. The following is an excellent choice. Some one correct me here if I'm wrong, but I think Ford still offers an HD 4r100 transmission that comes with an upgraded Tq converter and some other modifications. This is a very good deal and will also help with towing/DD/ and mild performance. And if memory serves me right, it's all for about $ 3600 +/- installed and comes with a 3yr/36000 warranty. Not bad at all.
So there's your starting point for a transmission.
A Stage 5-6 built 4R100 is gonna cost around $8K
And I too run GH tunes.
If I were to do it all over again (speaking ONLY for mods that is, be prepared to put some attention into the transmission first as others have said) I would take about $600 and invest in:
1) fuel regulated return
2) high flow CVD's
3) Hydra
Once you do the regulated return FIRST your fuel system will no longer require the very restrictive check valves inline with the fuel supply lines to each fuel rail. Hence the High Flow CVD fittings as the SECOND upgrade (both from Riff Raff). Then of course the Hydra. Of course then there is the in tank Hutch mod and the fuel lift pump and so on. And also of course before any mod this is all assuming there are no issues with your injectors or high pressure oil system.
2) high flow CVD's
3) Hydra
Stock-injector pickups (which I would say include up to 80% of the people here) aren't even breaking 300-ish horsepower.
No doubt high horspower can be made with them in place, but how much effort would it take to make that kind of power with them in place as opposed to removed. I noticed a significant power gain after swapping them out with the high flow CVD's. For $28 and about an hour of wrenching it almost seems like they are an under appreciated mod due to the cheap price and ease of install.
I put a modified valve body on my slushbox when I bought my truck 10 years ago. The transmission was rebuilt/replaced at 120K, I bought it with 146K on the clock, put a valve body on it, and have not had to do anything except fluid/filter changes since (knock on wood). I'm currently at 305K miles.
I'll wait until I need to buy one to do the bts tranny, but the valve body I may still do. Is the 6.0 cooler better than the aftermarket ones?
I only have mild mods on my truck. I figured no need for tranny work. It's too expensive.......Then, with my mild mods, hit the dyno. Yep, tranny lived about a week longer. Then it wasnt a "I'll save up money until I can afford it" deal. I got out the credit card.
And yes, the 6.0 cooler is WAY better. It is almost as big as our radiators.
Look at this on eBay:
https://www.ebay.com/itm/391716327676
Transmission Cooler for F-250 SD, F-350 SD, F-450 SD, F-550 SD FO4050104
I also installed one of these in the HOT SIDE i.e. BEFORE the cooler to prevent any particles from transmission contaminating the new cooler. It was worth it, 6 months later my TQ died, that filter was full of paste like particles. The shop that rebuilt my transmission didn't think too much of that little filter before we pulled it apart. Afterwards they were sold and have been installing them on the trucks when they rebuild a transmission. I converted 95% of my transmission lines to 1/2" when I went to the 6.0 cooler, that's why that posting below is for a 1/2" filter line, They also make 3/8" filters.
https://www.ebay.com/itm/150613214917
Magnefine 1/2" Inline Magnetic Transmission Filter
#28
This is what I used, brand new, no debris and excellent price point.
#29
2) high flow CVD's
3) Hydra
2) high flow CVD's
3) Hydra
#30
No... no you did not.
Its called Placebo... If you would like me to post the definition I can for you.
