RV Slide won't stay fully in/out
I know this question likely belongs in an RV forum. But honestly the quality of answers related to RV questions are often times better here, so I'll try this first.
We have a 2009 Arctic Fox slide in truck camper, model 811. We purchased the unit new and have used it a ton.
We just returned from 4 days camping and I encountered a problem with my slide out.
The motor which runs the slide in and out seems to work perfectly fine. The speed going in and out is completely normal- exactly what is has been since we bought it. Likewise, the sound of the motor is normal- no grinding or groaning or anything like that. But when I run the slide fully out, after I release the slide operation switch, the slide unit will not stay fully out. Rather, it will creep back inward about 2 inches or so and come to rest in that position.
When I run the slide fully in for travel, again, the unit will sorta unsquish itself from the fully closed seals about an inch or so. And during driving, the slide will tend to creep out. I needed to stop a couple of times in 100 miles of driving and run it back in as it would creep out 4-5 inches - especially on windy roads where going around corners would tend to ease it further into the "out" position.
I assume the electrical motor has some kind of a safety brake on it which may have failed in some regard? Would appreciate any input others with similar problems have had.
So I guess I'll answer my own question - or at least add a little more info.
I disengaged the manual brake release lever on my slide motor, then manually slid the slide out and in via the T-bar provided from the factory. And then re-engaged the brake lever. Now, everything seems to be working just fine again. Not sure exactly what I maynhave toggled by the above actions, but the slide unit stays fully open and fully closed.
The real test I suppose will be next weekend when I log another couple hundred miles with the camper on the truck.
Steve
I should add that I've run the slide in and out probably 20-30 times this weekend after I managed to get the brake working again. It seems to be working flawlessly still.
Considering that our camping trips usually involve at least 5-10 miles of dirt and/or washboard roads, maybe the bumping and jostling caused the little brake lever to slip out of its usual position *just enough* to disengage it? That's merely a guess on my part.
Yeah, good suggestion for sure. If it gives me any more issues whatsoever, I'll definitely look into it. I haven't shopped for a replacement AT ALL but I'm guessing they run about $200 or so. Kinda hard (right now anyway) to justify dropping that kinda coin on a part to keep in a drawer "just in case".
Steve
defyrftr
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
04-25-2014 12:39 PM
boo-yaa138
01-20-2009 04:00 PM
