AOD throttle valve adjustment
Received 4,130 Likes
on
And what are you running for a carb on what engine. Just want to confirm it.
on
on
So I assume that is a Autolite or Motorcraft 2100/2150 Carb.
Ok so why not just use a factory TV rod instead of the Lokar set up ? Far more reliable and easier.
Here is a recent subject on exactly that.
http://www.ford-trucks.com/forums/15...od-tv-rod.html
If the shifts are mushy you may need to up the PSI a bit. As long as it is not too high it won't harm the trans long term.
on
www.ford-trucks.com/forums/1500221-81-f150-351w-aod-tv-rod.html
Yes but the swap to and AOD TV rod is simple and cheap less then $20 from the wrecking yard and more reliable than the Lokar.
on
Not sure if you will ever be able to get the Lokar set up correctly on the 2100/2150 as the kit they make is not for the 2100 series carbs. Keeping the ratio correct from carb to the trans is even more important than the pressure setting.
It is a myth that the ratio is 1 to 1 that would mean that the shaft center-line to mounting stud is same distance from the shaft center-line on both the carb on trans, such is just not the case.
Also the TV link on the trans is different between an EFI trans and a Carb trans. If you do not have the right bits matched to each other it will never work properly.
This is something Lokar does NOT take in to account in their kit.
Swapping in an AOD is not complicated provided you know what you are doing and are aware that almost NONE of the after markets have the correct throttle to trans ratio.
Idle PSI on Carb application SHOULD NOT be less than 5 PSI and SHOULD be less than 5PSI on an EFI application.
Many of the after market AOD TV cables are wanting to say the least but can be made to work provided you are willing to do some fab work and calculations.
