Extra Battery Alternative's with Torklift's HiddenPower - Ford Truck Enthusiasts Forums
Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
Old 07-27-2017, 08:09 PM
Torklift Sheryl's Avatar
Torklift Sheryl
Torklift Sheryl is offline
SPONSOR
Torklift Sheryl has a good reputation on FTE.Torklift Sheryl has a good reputation on FTE.Torklift Sheryl has a good reputation on FTE.
The Torklift International HiddenPower is a specially designed and convenient auxiliary under vehicle battery mount for all types of Group 24, 27 and 31 twelve volt batteries such as lead acid, AGM, sealed, gel cell etc. Engineered as no drill installations with quick disconnect electrical connectors, the system quickly attaches to the truck’s frame under your truck.
The HiddenPower allows you to have extra battery power in your RV significantly extending the time you can run on your 12-volt systems. By adding an extra battery that is tied into your truck's electrical charging system, keep the battery charged and healthy and always ready for RVing with little to no maintenance.
The HiddenPower auxiliary battery is designed to also maintain its charge while RVing by becoming an extension of your RV's battery when your RV is plugged into your truck and will recharge via your RV's existing solar panels, generator, converter etc. at the same rate that your RV's batteries charge.
The HiddenPower auxiliary battery allows you to camp using battery power without draining your vehicle’s battery when coupled with the HiddenPower Wire Harness (sold separately).
The HiddenPower under vehicle auxiliary mount comes with Torklift International's Legendary Lifetime Warranty† and is proudly made in the USA.
† polymer battery box carries 1 year warranty
* Wire Harness carries a 90-day warranty
HiddenPower Features
  • Add additional batteries under your truck bed that are always charged up
  • Avoid wasting fuel and leaving your truck engine running while using electrical accessories such as lights, stereos, computer, etc.
  • Power your accessories without turning your truck engine on by having them directly wired into the extra battery
  • No-drill frame mounted with quick disconnect feature for battery service
  • Kept constantly charged and RVing-ready by your RV and truck’s charging system
  • Hidden when in use with no loss of ground clearance
  • Works with group 24 to 31 batteries
  • Designed for all types of batteries: lead acid, AGM, sealed, gel cell, etc.
  • Legendary Lifetime Warranty
  • Proudly made in the USA
ACTUAL PRODUCT COLOR IS BLACK. SHOWN IN YELLOW FOR CONTRAST
HiddenPower Wire Harness Features (sold separately)
  • Enables your HiddenPower battery to become an extension of your RV battery
  • Prevents your starting battery on your vehicle from being drained
  • Constantly charged for RVing or other uses by your truck's charging system
  • Universal design, works with all HiddenPowers
  • This wire harness completes your HiddenPower installation
  • Sealed Wire Harness to help protect against dirt and moisture
  • Fused to protect your vehicle’s electrical system
  • Detaches quickly via quick disconnect plug for battery service
Click here for more information on Torklift's HiddenPower.
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
01-19-2017 01:58 PM
Torklift Sheryl
04-27-2016 06:09 PM
Torklift Sheryl
03-03-2016 02:16 PM
Torklift Sheryl
03-17-2015 02:01 PM
Torklift Sheryl
02-10-2015 11:42 AM
Quick Reply: Extra Battery Alternative's with Torklift's HiddenPower
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
