Wont pump gas
Wont pump gas
I have a 2005 explorer limited v8. fuel pump went out so i dropped the tank and replaced it. Now it takes 1 gallon. then clicks off every 10cents. I dropped tank looking for kinked line and also blew out lines, I have replaced the valve by the battery.that comes from the intake to the tank. Ive read forums on this and seen videos on utube. I have the P1450 CODE. Unable to BLEED UP FUEL TANK PRESSURE.And the purge solonoid valve is costly. I believe it could be the ball in the tank or someone messed with anti-siphon valve. What I dont understand is ...Why is the fuel gauge run at 1/4 tank then goes to 1/2 tank. It has a lot of pressure when unscrewing gas cap.
as you put gas INTO the tank, AIR has to get out......... There should be something like a 1/2 inch black hose and tube connection from the top of the fill neck, to the top of the gas tank next to the fill line......... air comes OUT the tube and gas is filled into the tank.... See if it is kinked or plugged.
69issofine
05-31-2017 12:25 PM
86'F-150
84
01-22-2013 10:33 PM
Dead Meat
10-06-2009 12:52 PM
gracjm
05-21-2007 03:38 PM
1964_mezajd
01-17-2007 08:58 PM
