95 Bronco MAF big block swap issues
There is no map sensor this was a factory 302 mass air flow truck that I adapted the harness to the 460 that I put in. I've gotten several codes including 116, 998, and 412 . the 998 hard fail code seem to go away after I plug the mass air flow sensor back in but what Brian at fiveology racing and I are thinking is that either the mass airflow sensor may be good enough to have run the 302 but not have the parameters anymore to run the big block or vice versa with the ECU
check with Brian on that. that might be what's needed to get it to run right for what you have.
a tuner would be the best way to handle this but you can make it work the way its being done. it might take a another change of the maf tube to get it right. keep at it.
and this is where a wideband would come in handy to tell you if its right or not.
rdbcole1956
09-02-2014 01:58 PM
GuitarJesus
05-22-2012 06:49 AM
bob1987f
03-10-2009 09:54 PM
