Gear Change Now Speedometer Is Off??? - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 07-25-2017, 10:49 PM
ceetwarrior's Avatar
ceetwarrior
ceetwarrior is offline
ceetwarrior is gaining momentum as a positive member of FTE.
Question Gear Change Now Speedometer Is Off???
Hey guys, kinda stumped here. I thought changing gears didn't have any affect on the speedometer? I changed from 3.73's to 4.10's in my '03 E250. My speedo is off by at least 8-10mph at 70mph now. Crazy part is, it still governs me at 89mph even though I know I'm only doing about 75 which is not gonna work for how much interstate driving I do.
Is there different tone rings for different gear ratios in these vans? Do I need to find a '03 E350 computer? How else can this be fixed?
Thank you in advance!
Old 07-26-2017, 04:59 AM
Im50fast's Avatar
Im50fast
Im50fast is offline
Nice guy!
Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.
the van tells you the speed based on transmission output shaft speed. But it doesn't know you changed the ratio.
In the old days you would have to change the speedo cable gear but I don't think your 03 has that. I think you're going to have to get a "tuner". Everyone here like Mikes 5 Star. It's basically your only reasonable choice.
Prepare yourself for a LOT of responses to your post. Lots of good advice will follow; from van guys with lots more experience and knowledge than you and I
It is governing you to 75mph because it thinks you are going 89.
Changjng to a E350 computer won't help. Unless you find a 2003 e350 computer from a van with 4.10 gears. And even then, I don't think it'll work.
Old 07-26-2017, 07:07 AM
ceetwarrior
Originally Posted by Im50fast View Post
.... Unless you find a 2003 e350 computer from a van with 4.10 gears. And even then, I don't think it'll work.
I think most all 350 vans come with 4.10's which is why I'm wondering if I can't just swap that out for $35 from a local Pull N Pay. I wonder what years will interchange correctly with my 5.4 / 4R75W / 4.10's. I don't mind doing a tuner if I have to but $35 ECU would be easy and cheap.
Old 07-26-2017, 07:21 AM
Im50fast's Avatar
Im50fast
Im50fast is offline
Nice guy!
My 07 E350 has 3.73's
Old 07-26-2017, 12:06 PM
EagleFreek's Avatar
EagleFreek
EagleFreek is online now
EagleFreek is starting off with a positive reputation.
My 2000 E350 has 3.55's.
Old 07-26-2017, 03:02 PM
vettex2's Avatar
vettex2
vettex2 is offline
vettex2 has a good reputation on FTE.vettex2 has a good reputation on FTE.
mine has 4.10's
Old 07-26-2017, 10:30 PM
ceetwarrior
Guess I'll be searching hard to find exactly what I need. All the 350 vans at my company are "super duty" and I know they have 4.10's. What brand of tuner has van tunes and speedo recal stuff?
Old 07-27-2017, 07:24 PM
Im50fast's Avatar
Im50fast
Im50fast is offline
Nice guy!
mikes 5 star is the only way to go.
So sayeth the crowd on this forum.
Old 07-28-2017, 09:35 AM
ceetwarrior
Thanks for the tip, I'll look it up later. I did some programmer research yesterday and kinda limited it down to the hypertech 742500 speedo fix $229, or the hypertech 42500 speedo fix + tuner for $299.
LeoJr
03-31-2012 09:08 PM
idealtrucks
04-21-2006 08:31 AM
MikeGV
09-26-2005 09:30 PM
Superdave
05-28-2004 12:06 AM
1yamman350
Ranger & B-Series
08-16-2003 09:47 PM
Quick Reply: Gear Change Now Speedometer Is Off???
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
