Truck bed replacement
Jul 25, 2017 | 06:24 AM
Just curious how difficult it is to swap truck beds on a super duty. My 04 is rusted out enough that it has dropped down towards the cab.
There's a gentleman on CL that sells beds that he has brought up from the south so I can get a replacement bed.
I assume I'd be best to buy a bolt kit off eBay to make life easier.
Any other advice?
Thanks!
Jul 25, 2017 | 07:12 AM
It is pretty much as it appears. Disconnect fuel filler and all wiring. Cut off bed bolts, lift away.
Don't fuss with trying to remove and reuse the bed bolts. It will only frustrate you and break Tork bits.
Jul 25, 2017 | 08:23 AM
yep.. undue wiring.. fuel to bed connections.
unbolt or cut heads off bolts...
4 guys and lift...
reverse for install.
Jul 25, 2017 | 10:34 AM
Is there a simple wire disconnect or do I need to undo each of the tail lights and fish them back?
Jul 25, 2017 | 11:02 AM
Quote:
Originally Posted by
garmford
It's simple! You unplug a single connection on the bottom of the old bed, remove the taillights, then reverse the order w once the new bed is on.
Jul 25, 2017 | 04:27 PM
Sounds easy enough!
Thanks to the advice!
Jul 28, 2017 | 08:31 PM
what part of wisconsin are you for craigslist because i will need a box in the future and wouldnt mind getting a ballpark cost
Jul 28, 2017 | 09:02 PM
Im northwest of Milwaukee. I haven't called the guy yet but I'm guessing around $1000. He had some mediocre ones for $750. My truck has almost 300000 miles on it so I don't need anything too nice.
Jan 18, 2018 | 05:27 PM
How hard is it or is it possible to do a cab swap on a 2006 f150 to a 2013 f150
Hank85713
1983 - 2012 Ranger & B-Series
Dec 9, 2012 04:40 PM
Epd444
Jun 5, 2011 09:03 PM
menzfamfour
1997 - 2003 F150
Nov 10, 2010 04:33 PM
bmvtr
Jul 31, 2007 06:19 PM
Gulf001
Dec 9, 2003 03:21 PM
