ANOTHER SPARK PLUG QUESTION
Old 07-24-2017, 10:01 PM
TOM B1's Avatar
TOM B1
TOM B1 is offline
I have a 2008 explorer with a 4.6 engine. What date code did ford change to the newer style spark plugs, one piece. The tag on the valve cover said the engine build date is 220408. I think this is May 22nd of 2008. part number of the engine is 7S302AC.
Does this engine have the 2 piece or the one piece plugs.
Old 07-27-2017, 11:55 PM
swshawaii's Avatar
swshawaii
swshawaii is offline
Compare your door pillar sticker build date to your valve cover. 4.6L 3V before 11/30/07
http://www.revbase.com/BBBMotor/TSb/...dPdf?id=142690
BBB Industries - TSB's & Wiring Diagrams
Brown coil boots are used on the newer 3V heads. Black coil boots are used with the older design heads with the two piece plugs.
4.6l 3v Spark Plug Removal Instructions | Ford Explorer and Ford Ranger Forums - Serious Explorations
Old 08-08-2017, 08:53 PM
TOM B1's Avatar
TOM B1
TOM B1 is offline
Thank You, as it turned out I did have the brown boots and the plug where not the 2 piece.
The gap on the OLD plugs with 104000 miles was over 70 thousands, Wow
mwacosta$
1999 to 2016 Super Duty
16
04-15-2018 10:02 AM
berry1234
05-22-2012 08:34 AM
allen07ford150
2004 - 2008 F150
13
11-21-2010 12:14 PM
2stepn
02-14-2010 11:35 PM
WilZol
2004 - 2008 F150
03-18-2008 07:24 AM
Quick Reply: ANOTHER SPARK PLUG QUESTION
