1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Oil cooler pump. 6.4
Old 07-23-2017, 09:57 PM
_SUP3RSTROK3R_'s Avatar
_SUP3RSTROK3R_
_SUP3RSTROK3R_ is offline
Anyone have any problem with oil cooler pump throwing the wrench light at you?? Dealer says it cools the oil and mine could be clogged a bit.. cost of total job around 8-10 k. And take cab off.
It seems when engine gets hot wrench light comes on cause not cooling oil down properly... it overheated. gauges were very high.. once when I was in full boost towing a ranger up a hill. First time it ever happened.. pulled over for 5 mins than started temp went back normal and finished tow no problem after that cause I kept boost lower! Anyone have this problem or any info thanks
Old 07-24-2017, 08:33 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is online now
the oil cooler is a unit that has both oil and coolant running thru it via seperate passage ways.
this unit can clog mostly on the coolant side (if you do not have a coolant filter) or on the oil side (if you do not have a bypass oil filter).
the coolant in the 6.4 is a test every 20K miles and replace as needed. if worn, the particulants in the coolant can drop out of suspension and clog the oil cooler and cabin heater core.
some folks have had success back flushing the coolant side of the oil cooler to remove the sluge.
some folks have also installed a separate true air oil cooler .
if mine were to get clogged, I would go the seperate air oil cooler route until I have a good reason to pull the cab off.
Old 07-24-2017, 12:17 PM
_SUP3RSTROK3R_
Great info spearkerfritz ty for your reply....
Is the coolant filter easy to access? Prolly hasn't been changed... is there a video or link to detail about back flushing the coolant pump. Or link/ video to installing new air cooler? How much in cost if you don't mind me asking.. ty
Old 07-24-2017, 04:25 PM
Tofan's Avatar
Tofan
Tofan is offline
It's not the "coolant pump" that gets clogged. It's the actual oil cooler that has small passages for coolant and for oil.
https://www.perfdiesel.com/assets/im...4OILCOOLER.jpg
If you have a bad oil cooler, then this is a CAB OFF repair. Even with the CAB off, you have to remove both turbos and a plethora of other things to get down to the oil cooler, very hard repair.
Old 07-24-2017, 05:01 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
Anything can be done with the cab-on; there's a Ford procedure for cab-on oil cooler repair. It's a question of how long those six little turbo inlet bolts take if they round off though. The specialty tool is not well regarded for the task, they break pretty easily:
Snap-on Inc. 3/8"-drive Turbo Inlet Pipe Socket, No. S6210 in Specialty Tools
This is the cab-on engine removal procedure, you would have to do 80+% of this work to get to the oil cooler, most of the first 138 steps:
Old 07-24-2017, 07:29 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
Old 07-25-2017, 09:16 PM
_SUP3RSTROK3R_
*bump thread***
Old 07-25-2017, 09:18 PM
_SUP3RSTROK3R_
*bump thread***
Old 07-25-2017, 10:15 PM
_SUP3RSTROK3R_
Great info is there a link or thread going through back flushing coolant side of oil cooler
Old 07-25-2017, 10:17 PM
_SUP3RSTROK3R_
Ok repair at cost probly around 6-10k I bet
Bodo Malo
10-22-2018 12:36 AM
FL SuperDuty
12-22-2017 10:29 AM
Taylor Dennis
09-02-2015 04:09 AM
Thermo2008
08-14-2011 08:03 AM
OneTon4Fun
12-06-2010 11:10 AM
Quick Reply: Oil cooler pump. 6.4
