Front of engine oil leak
Hi everyone;
Was replacing my cracked and leaking charge air cooler pipe Friday evening and noticed oil all over the place at the lower front of the engine. It has been a few months since I've been under the truck. No drips on the ground so it must be a slow leak while driving. Oil level is fine so it hasn't been leaking for long.
Any ideas from this limited two picture view? Front main seal? I've been reading the vacuum pump leaks oil as well but I'm not sure where that is other than driven by the HPFP. I took additional pictures but those were useless, it's a bit cramped in this area.
In the past ten months I've had the turbo coolant inlet pipe leak repaired and then the DEF heater failed,which means replacing the entire pump of course. The wastegate solenoid air compressor noise started some time ago as well at shutdown but I haven't been concerned about that (it doesn't seem to cause an issue). 96,000 miles.
Last edited by kper05; 07-24-2017 at 09:33 AM. Reason: Correction, sender assembly, not DEF pump.
Hi everyone;
Replacing the wastegate control solenoid would resolve that concern.
Fastfwd
1999 to 2016 Super Duty
01-11-2015 04:48 PM
