2003 engine swap into 2006
07-22-2017, 09:36 AM
on
Did the swap and all works good except the boost is often at 3psI then sometimes it works good. Used the 03 harness. So did I need to change a wire or sensor or use 03 pcm?? I was told maf sensor might cause issues but no codes for it.
07-22-2017, 09:37 AM
on
All the
Swap info I've seen is the other way around with new engine into older truck.
07-22-2017, 10:54 PM
Post baro map ebp koeo and at idle and at 2500 RPM
03 used map
06 used ebp for turbo calc
Did you install just a base engine or ?? Swap any turbo sensors etc more info
07-24-2017, 01:49 PM
on
here are some numbers
I used the complete wiring harness, sensors, ect from the 2003 and just plugged it into the 2006 pcm.
KOEO......... EBP 0.00v, 6.3psi. MAP 1.32v, 14.75psi. MAF 0.04v, 0 lb/min. BARO 14.21psi. VGT duty 0%
KOER idle......... EBP 0.00v, 6.3psi. MAP 1.31v, 14.46psi, MAF 1.51v, 4.72 lb/min. VGT duty 42.9%
KOER 2230rpm....... EBP 0.00v, 6.3psi. MAP 1.50v, 16.42psi. MAF 2.66v, 15.18 lb/min. VGT duty 52.37%
07-24-2017, 01:51 PM
I would have kept the 06 HPO system... a lot more reliable. save the old parts before disposing of the engine.
Richard
07-24-2017, 01:53 PM
on
Quote:
Originally Posted by
DarkStarMedia
Richard
I know, just did it because I had it kicking around...
07-24-2017, 02:34 PM
It's your ebp better make sure that it is plugged in
07-25-2017, 02:58 PM
on
BLADE35
Seems the new sensor I put in was faulty...
07-25-2017, 10:49 PM
Didn't the 03' use inferred EBP? Why it's reading zero.
07-25-2017, 10:53 PM
on
WatsonR
I have been told that too but it reads the sensor and applies boost better with it in and in working condition..
07-25-2017, 11:15 PM
Looking at your readings... they are 0v and 6.3psi across the board. Normally MAP+BOOST=EBP. And unplugged you can tell a difference in boost?
jason90f150
30
02-13-2016 09:02 PM
rowekmr
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
07-15-2015 11:25 AM
Fordflanigan
10-27-2010 06:55 PM
half nut
Computer Chips & Tuners
04-29-2008 08:21 AM
